Hello folks;
I'm wondering if any of you advanced modelers can advise me on a strange twitch going on with sheet metal sketched bends.
I've built a couple of metal parts for a bicycle and I need to have the dropouts bend to accept the chainstays. Unfortunately after I build the part and sketch my bend line, This happened once before and, not being able to find the right forum, I ended up redrawing the part which resolved it in a roundabout way. But there must be a way to repair this
problem quickly.
Sam, I opened your model and made a new sketch (Sketch3). This is a little trick we use at our sheet metal shop to configure bend lines. It not only marks where to bend the part in our press breaks but helps the operator as there is no lay out needed. The cut is large enough for our laser to cut but small enough to not effect the part. This helps when you get into sketched bends as you can just select the center of both cut-extruded holes; making no need for construction lines in your sketched bend. Hopefully this helps. I have attached some images for reference.
Regards,
Matt
