1 Reply Latest reply on Sep 26, 2013 5:14 PM by Keith Rice
    Tool for rearrange the dimension lable position
    Mahesh Revanwar
      Please tell me, is there any API to rearrange the dimension lable position through code?
        • Re: Tool for rearrange the dimension lable position
          Keith Rice
          Mahesh,
          You will need to get the IDisplayDimension pointer for that dimension, then use IDisplayDimension::GetAnnotation to get the IAnnotation pointer, then use IAnnotation::SetPosition to change the position.
          For example, select a sketch and then run this code. It will put a dimenion at the origin.
          Dim swFeat As SldWorks.Feature
          Dim swDispDim As SldWorks.DisplayDimension
          Dim swAnn As SldWorks.Annotation
              Set swModel = swApp.ActiveDoc
              Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
              Set swDispDim = swFeat.GetFirstDisplayDimension
              Set swAnn = swDispDim.GetAnnotation
              swAnn.SetPosition 0, 0, 0
          Keith
          SolidWorks API Tutorials
