Is there a way to get the Bend Allowance type (Bend Table, K-Factor, Bend Deduction, Bend Allowance, Bend Calculation) into the Cut List, BOM or Custom Properties? It is possible to get the numeric value with "SW-Bend Allowance@@@Cut-List-Item1@****.SLDPRT" but it's only half the story.
Thanks.
Hi Eric,
You can get the K factor to show up in a BOM & Custom properties.
In custom properties "Edit list" add K Factor as a property name and under the Value/Text Expression "D2@Sheet-Metal"
I don't use bend tables etc but the principal should work for the different work practices
A single click on sheet metal brings up the thickness,radius and K factor on my parts
I have these saved in my template custom properties so they fill by default any time I make a sheetmetal part
In the BOM on my drawings I have a column for each property so its auto filled.
I use the BOM as a final check to make sure all the SM parts in an assembly have the correct K Factor and bend radius.
