5 Replies Latest reply on Dec 29, 2016 8:56 AM by Gabriel Bueno
    Change a global variable using a macro?
    Alex Brewer
      I'd like to change a global variable using a vb macro. How do I accomplish this?
      Here's my attempt that does nothing:
      Dim swEqnMgr As SldWorks.EquationMgr
      Sub main(dim_name As String, dim_val As Long)
          Set swModel = swApp.ActiveDoc
          Set swEqnMgr = swModel.GetEquationMgr
          Dim eqn As String
          Dim val As Double
          i = swEqnMgr.GetCount
          While i > 0
              eqn = swEqnMgr.Equation(i)
              a = InStr(eqn, "@")
                  If (a = 0) And eqn = dim_name Then
                       swEqnMgr.Value(i) = dim_val
              i = i - 1
          Wend
          swModel.ForceRebuild3 False
        • Re: Change a global variable using a macro?
          Keith Rice
          Alex,
          IEquationMgr::Value is get-only. You cannot use it to set a value. You need to use IEquationMgr::Equation to change the value. There's many different ways you could write code that does this, but here's one way:
          Const VARIABLE_NAME As String = "var1"
          Const NEW_VALUE As String = "2"
          Dim i As Integer
          Dim vSplit As Variant
              For i = 0 To swEqnMgr.GetCount - 1
                  vSplit = Split(swEqnMgr.Equation(i), " = ")
                  vSplit(0) = Replace(vSplit(0), Chr(34), Empty)
                  If vSplit(0) = VARIABLE_NAME Then _
                      swEqnMgr.Equation(i) = Replace(swEqnMgr.Equation(i), vSplit(1), NEW_VALUE)
              Next i
          Hope this helps. By the way, did you know that you can run VBA code in equations? Check this out --- it's pretty cool.
          Keith
          SolidWorks API Video Tutorials
