Hello, I'm new in the designing world and I'm doing an engine design that is a bit difficult to create. Could someone please tell me how can I insert some holes in a curve surface, which must be (the hole) 25 degrees to the axis of rotations? Basically how can I make angled holes on a curved surface. Thank you. Sorry for my English, if it's not understandable.
You can create a line at the 25° and then use it to create a plane perpendicular to the line
or
you could create a rectangle at 25° and Rotate-Cut the rectangle around it's axis to create a hole.
Attach your file (or a simplified representation) here if you can't figure it out.
