Currently, on my drawing title blocks I have a "where used" section. This is populated via EPDM data card input. As it now stands, users enter TEXT to state the next assembly where the particular part/sub-assembly is used.
I would like to make use of the "where used" data in EPDM and reference THAT data to populate the data card, which in turn, populates the drawing title blocks.
I was thinking that is there was a like an "SW" variable in EPDM that I could reference that would be the key.
Any suggestions?
dave
I imagine this will be quite dificult, if even possible. maybe with a macro?
1) this information would have to be based off of the model - the drawing is NOT used anywhere. (unless you "paste as reference" which would be a pain)
2) the where used information can easily change without this file's version changing, so keeping it up to date would require additional check out/ check ins.
