http://www.youtube.com/watch?feature=player_detailpage&v=mQ6WNWOnH14#t=219
I want to make an object
http://www.youtube.com/watch?v=vTMjTreGHc4
interfer in such way that it behaves like a poorly designed gear where rectangles actually push on each other and cause each other to move out of the way.
I was too lazy to draw actual gears.
Tarakan,
You can turn on "Physical Dynamics" in the Move command to get that type of reaction. If your assembly or the parts are fairly complex you might have to move slowly to make sure that the calculations can keep up with the position of your parts.
Jerry S.
