I'm having a problem trying to sketch at the moment: all of my line endpoints are being covered with relation icons, so I can't select the points - only the relations. Does anyone know of a way to make SW display the icons offset from the points, where they are usually?
I've tried closing the part file and reopening with no success. I haven't closed out SW yet because I'm in the middle of something and I'd rather not save certain parts. For a temporary fix I'm hiding the icons, but this has happened to me once or twice before as well so it'd help to find a solution.
Thanks in advance!
-Bryan
I should've noted I'm using SW2013. I found an old post describing a similar problem in SW2009, so it must be a bug that hasn't been eliminated. I'm going to mark this as answered as there likely is no solution.
