I need to convert an assembly with many parts into a single part file to perform a FEA studies.
Is there an export / import option available that will allow me to mesh and run study?
File enclosed
Thanks In Advance
Twaka
File enclosed
Thanks In Advance
Twaka
File enclosed
No files enclosed.
BTW if you can open the assembly then save your assembly as part and use as required.
In the assembly go to File Save As. In the save as window, pick save as type as Part. Select the appropriate option and save
No files enclosed.
