Attached is a simple model of a rubber block (non-linear properties). I am having some problems with its material properties.
I have satisfied all the necessary fields in order to define the material, but I think the stress-strain curve I am using is causing some problems (derived from experiment).
Model details:
- Symmetry constraint on 2 side faces.
- Load currently just a 1 N force applied across top and bottom surface. (force vs time .dat file exist not applied yet to simply problem)
- Automesh
- Used reference geometry on bottom surface
I am pretty sure the problem lies within the material properties. I have simplified all the variables and it seems to solve if I use a simple material
Could someone please help. Thanks
What version and sp?
Have you spoken to your reseller about this?
Just to confirm, with a linear material the problem solves without issue?
What material model for nonlinear do you want to use?
In the long run, what are you trying to learn from the study?
