0 Replies Latest reply on Sep 19, 2013 8:24 PM by Yong Ning
    SwFeat.Select in AssemblyDoc
    Yong Ning
      Sub ll()
        Dim swApp As SldWorks.SldWorks, swModel As ModelDoc2, swAssy As AssemblyDoc
        Set swModel = swApp.ActiveDoc
        Set swAssy = swModel
        Dim swComp As Component2, vComp As Component2, vModel As ModelDoc2
        Dim swFeat As Feature, vFeat As Feature
        Dim SwSelMgr As SelectionMgr, Str
        Set SwSelMgr = swModel.SelectionManager
        Set swFeat = swModel.FirstFeature
        Do While Not swFeat Is Nothing
           If swFeat.GetTypeName = "Reference" Then
               swFeat.Select False ' → can be select feature in Feature tree
               Set swComp = SwSelMgr.GetSelectedObjectsComponent(1)
               Str = swComp.GetModelDoc.GetTitle
               If UCase(Str) Like "*SLDASM*" Then
                 Set vModel = swComp.GetModelDoc
                 Set vFeat = vModel.FirstFeature
                 vFeat.GetFirstSubFeature
                 Do While Not vFeat Is Nothing
                    If vFeat.GetTypeName = "Reference" Then
                       Debug.Print vModel.GetTitle, vFeat.Name, vFeat.GetTypeName
                       vFeat.Select False → don't select feature in Feature tree
                    Set vFeat = vFeat.GetNextFeature
                 Loop
           Set swFeat = swFeat.GetNextFeature
        Loop
      Question
      swFeat.Select False→can be select feature in Feature tree
      vFeat.Select False→ don't select Feature in Feature Tree
      Help me , How to select feature in picture.
      Sub ll()
        Dim SwSelMgr As SelectionMgr, Str, AsmFile
               swFeat.Select False
                AsmFile = swComp.GetPathName
                 Set vModel = swApp.ActivateDoc2(AsmFile, False, 0)  'swComp.GetModelDoc
                 Debug.Print
                 Debug.Print
                       vFeat.Select False
                 Loop
                 swApp.CloseDoc AsmFile
        Loop
      Sub fdsaffafdasfdasfdsafdasfdsafdewrqtq()
        Dim oDic As New Dictionary, Str
        Dim SwModel As ModelDoc2, swFeat As Feature, SwAssy As AssemblyDoc
        Set SwModel = Application.SldWorks.ActiveDoc
        Set SwAssy = SwModel
        Dim SwSelMgr As SelectionMgr, SwComp As Component2
        Dim SelArray(1 To 1)
        Set SwSelMgr = SwModel.SelectionManager
        Dim vChildComp, vComp As Component2
        Dim vModel As ModelDoc2, vFeat As Feature
        kk = 1
        Dim Rng As Range, oRng As Range, FindStr
          FileName = SwAssy.GetPathName
          Path = Left(FileName, InStrRev(FileName, "\"))
          FileName = Left(FileName, InStr(FileName, "卧式储罐") + 4) & "Horizontal Tank.xls"
          Set Sht = OpenXls(FileName).Sheets("材料表")
          Set oRng = Sht.Range("T:T")
          vChildComp = SwAssy.GetComponents(False)
          For ii = 0 To UBound(vChildComp)
             Set SwComp = vChildComp(ii)
             Set vModel = SwComp.GetModelDoc
             If Not vModel Is Nothing Then
               'If Not oDic.Exists(vModel.GetTitle) Then
                 oDic(vModel.GetTitle) = ""
                 'Debug.Print ii, kk, vModel.GetTitle, Space(2),
                 Set Rng = oRng.Find(what:=vModel.GetTitle)
                 If Not Rng Is Nothing Then
                   sFileName = Path & Rng(1, 2)
                   Debug.Print kk, sFileName, SwComp.GetPathName
                   'boolstatus = SwComp.Select3(False, Nothing)
                   SwComp.Select3 False, Nothing
                   bRet = SwAssy.ReplaceComponents(sFileName, "", True, True)
                   If Not IsEmpty(Rng(1, 3)) Then
                      Debug.Print vModel.GetTitle, Rng(1, 3).Address
                      RngReplaceEqu vModel, Rng(1, 3)
                 kk = kk + 1
               'End If
          Next ii
