I have been using solidworks 2011 for my design, I am facing few issues while trying to update my entire assembly by using a design table.
Problem:
I have created an assembly with nearly 50 parts and 5 sub assemblies. Each and every part and subassembly is linked to their respective excel through design table. I will modify the dimensions repeatedly for this assembly so only used design table. I will change the dimensions in all the excel sheets, and then i will open the main assembly file.
While it start updating each and every part in the assembly, few times it couldnt able to update properly or it gets crash. I couldnt able to find the actual reason for this problem.
System configuration is also a decent one with i7 processor and 16 gb ram with external graphics card. Please help me in this issue....
Hello Kandasamy,
If you are experiencing a repeatable crash, it would be best to use the SolidWorks Rx tool (Start > All Programs > SolidWorks 2011 > SolidWorks Tools > SolidWorks Rx) and click on the Diagnostics tab to see whether you have any red or yellow X's in the list, in case it's a simple fix such as an outdated graphics card driver. If everything checks out, then click on the Problem Capture tab, reproduce the crash, and send the Rx report to your VAR for a detailed analysis.
Cheers,
Jim.
