7 Replies Latest reply on Dec 26, 2013 5:41 AM by Nazar Chaykin
    Traverse assembly problem (Referenced config not same as config name)
    Michael Caulton
      I have a problem when traversing an assembly, the configuration name differs between using the Comp.ReferencedConfiguration and Config.Name methods
      I have simplified the code but it shows the problme I am having. Sample assembly attached too which has configurations etc setup.
      Macro prints swChildComp.ReferencedConfiguration + " vs. " + swChildConfig.Name into debugger window. I would expect these to be the same but they are not as per the debugger results shown below code. Some are the same some are not.
          Dim swModel As ModelDoc2
          Dim swAssy As AssemblyDoc
          Set swModel = swApp.ActiveDoc
          If swModel.GetType = SwConst.swDocASSEMBLY Then
              Set swAssy = swModel ' Top level assembly
              TransverseComponent swApp, swAssy, 1
      Sub TransverseComponent(swApp As SldWorks.SldWorks, swAssy As AssemblyDoc, nLevel As Long)
          Dim vChildComp As Variant
          Dim i As Long
          Dim Indent As String
          Dim swChildComp As Component2
          Dim swChildModel As ModelDoc2
          Dim swChildConfig As Configuration
          Dim swChildAssy As AssemblyDoc
          For i = 1 To nLevel
              Indent = Indent + "  "
          Next i
          vChildComp = swAssy.GetComponents(True)
          For i = 0 To UBound(vChildComp)
              Set swChildComp = vChildComp(i)
              Set swChildModel = swChildComp.GetModelDoc2
              Set swChildConfig = swChildModel.GetActiveConfiguration
              ' Compare assembly reference name to model config name
              Debug.Print Indent + swChildComp.ReferencedConfiguration + " vs. " + swChildConfig.Name
              If swChildModel.GetType = swDocASSEMBLY Then
                  Set swChildAssy = swChildModel
                  TransverseComponent swApp, swChildAssy, nLevel + 1
          Next i
      DEBUGGER:
        HCC0102-L1090-MS vs. HCC0102-L1090-MS
          HCC0102-1-L1070-MS vs. HCC0102-1-L1070-MS
          HCC0102-2-MS vs. HCC0102-2-MG
        HCC0118-L1700 vs. HCC0118-L1260
        HCC0119-L1700 vs. HCC0119-L1080
        HCC0301-L1700-MS vs. HCC0301-L1700-MS
          HCC0301-1-L1700-MS vs. HCC0301-1-L1700-MS
          HCC0101-4-L1700-MS vs. HCC0101-4-L2210-MS
        HCC0302-SS vs. HCC0302-MG
        • Re: Traverse assembly problem (Referenced config not same as config name)
          Artem Taturevych
          IComponent2::ReferencedConfiguration is the configuration used by a component. The one you setup in the assembly. It means that single document can has multiple instances of components in difference referenced configurations. IModelDoc2::GetActiveConfiguration is a configuration currently active in the document (the configuration which was active while saving the document). This is the one you change in Configuration Tree tab in Feature Manager Tree. It is only possible to have single active configuration per document at a time.
          ____________________________________________________
          Regards,
          Artem Taturevych, Application Engineer at Intercad (Australia)
          translationXpert – add-in to translate SolidWorks models
          myIntercad an integrated tool for SolidWorks Professionals
          LinkedIn SolidWorks API Education Group
            Michael Caulton
            Thanks Ivana. Dont know how that one didnt come up in my searches.
            Here is my code someone else might find useful
            Code trolls through a SW assembly getting the configuration specific custom properties and printing them to the debugger.
                Dim i As Long
                Dim bRet As Boolean
                Dim swChildModelDocExt As ModelDocExtension
                Dim swChildCustPropMngr As CustomPropertyManager
                Dim ChildConfigName As String
                Dim Val As String
                Dim ValOut As String
                Dim vPropNames As Variant
                Dim j As Long
                ' Indents the text so it looks pretty in the debug window
                For i = 1 To nLevel
                Next i
                    ' Get referenced configuration name
                    ChildConfigName = swChildComp.ReferencedConfiguration ' name of configuration we are interested in
                    Set swChildModelDocExt = swChildModel.Extension
                    Set swChildCustPropMngr = swChildModelDocExt.CustomPropertyManager(ChildConfigName) ' Sets the custom prop manager to the referenced configuration
                    Debug.Print ChildConfigName
                    ' Prints details of specific custom property within referenced configuration
                    swChildCustPropMngr.Get2 "Part Number", Val, ValOut ' Can use .Get4 if using SW2011 or newer
                    Debug.Print Indent + "  " + "Part Number" + " = " + ValOut 'Prints the configuration name as per the custom properties
                    ' Prints details of all custom property within referenced configuration
                    If Not swChildCustPropMngr Is Nothing Then
                        swChildCustPropMngr.GetAll vPropNames, Empty, Empty
                        If Not IsEmpty(vPropNames) Then
                            For j = 0 To UBound(vPropNames)
                                swChildCustPropMngr.Get2 vPropNames(j), Val, ValOut
                                Debug.Print Indent + "  " + vPropNames(j) + " = " + ValOut
                            Next
                    ' Traverses next level down if file is a SW assembly
                Next i
