Internal Flow Result with that don't make sense
Question asked by James Lin on Sep 14, 2013
Latest reply on Sep 30, 2013 by James Lin
Hi Eeveryone,
I have just setup a simple internal flow simulation with a 11g/s mass flow rate of air as inlet and the air exits to a static pressure of 14.7psi. There is a heat source in the flow path so that air flow is going to take the heat out. Everything runs find but the result is non-sense, because the outlet air temperature is even lower than the inlet air temperature. Please see below.
Anyone can help me to find out what did I do wrong here?
