Hi All,
I am trying to use Solidworks Simulation to analize a design that I have already validated by hand calcs and physical testing. Basically I have a flat rectangular plate that has a uniform pressure on one side. The opposite side is supported by a "picture frame" structure and a no-penetration constraint such that the center of the plate is free to deflect. The edges of the plate are not constrained in the lateral direction. Basically this arrangement should allow the plate to be in pure bending with minimal membrane stress. My Von Mises Stresses and Stress Intensity (Tresca) values are what I expect. However, if I create a pressure vessel analysis and then try to linearize the stresses at the center of the plate, I get huge membrane stresses. Additionally, the stress intensity values listed under the linearized results are way higher than those reported in the stress intensity results plot. I've attached some pictures to help explain. Am I misinterpreting these linearized results? The pressure vessel study was set up to use the results from only one analysis. I am thoroughly confused by this result. Can anyone help? I appreciate any pointers!
Please let me know if anything is not clear.
Haven't played with this functionality much. Can you post your model?
Also have you checked the solidworks kb? What version and sp are you using?
I think your investigation method is good, check if the other plots are working. Maybe it is just a display issue. Have you tried using the plots to come up with an estimate manually based on the results coming from the software? What values are you expecting?
