Hi All,
Quick sketching question. I need to get the circle on attached sketch coincident with the corners of the rectangular tube while still maintaining the center / midpoint relationship between the two. I can trig it out to get close but then when I go to cut extrude, I get some weird pieces still there. Not sure what relationship to add at this location. Thanks!
I would use a construction line from the origin to the circle centre for the vertical constraint, and use a Coincident constraint between the circle & a vertex.
