One of the first things I have noticed in the EPDM vault is that assemblies, parts and drawings are not shown in a nested view. In workgroup you see the assembly only, which when selected will open up to reveal the parts and drawings associated with the assembly. In the EPDM vault you see all SW files on the same level. I want to set the view to a nested view by default. Can this be done? I have searched high and low and have found no reference to this.
Thanks for the help.
This is what I see in EPDM
This is what I want.
It can't really be done. Coming from WPDM, its a bit of a letdown. The best you can do is sort by file type and just remember what is the top level assembly, or manually make a tree with folders. The open dialog in SOlidworks does have a filter to Top Level assembly option, which is semi helpful.
