Hi people.
When I try to save as jpg, all the edges dissapear. It doesn't matter if it's in shaded or wireframe mode, the problem is the same. This means, that I can't save a wireframe model as jpg, as there are absolutely no lines/edges visible on the jpg.
I have tried just about everything I can think of to solve this problem, but no luck so far.
The support team here in Denmark couldn't help me eighter.
Attached you can see an example:
Your help would be greatly appreciated.
Peter
Welcome to SolidWorks forums Peter.
Check if your video card is approved one and also the drivers are up to date. If this is OK then try making a PDF out of the SolidWorks and check the quality in there. Also place a view in drawing and do a save as JPG from drawing and check.
You might also find this post helpful for your future reference.
