8 Replies Latest reply on Sep 12, 2013 7:12 PM by Artem Taturevych
    Get all components from Assembly by using SolidWorks API 2011 and 2013
    Sergey Lysenko
      I'm using SW 2011 SP3 and SW 2013 SP4.
      I'm trying to get all components from big assembly and in the end I get different result of number children.
      For SW 2011 the result is 7373 components for SW 2013 the result is 1374 components.
      Can you explain why I have different results? API for getting components was changed for SW 2011 and SW 2013?
      Take a look at the code below, please:
      Object swDocSpecificationObj = swApp.GetOpenDocSpec(fileName);
      var swDocSpecification = (IDocumentSpecification)swDocSpecificationObj;
         swDocSpecification.Silent = true;
         swDocSpecification.ReadOnly = true;
         swDocSpecification.UseLightWeightDefault = false;
         swDocSpecification.LightWeight = false;
      IModelDoc2 swDoc = swApp.OpenDoc7(swDocSpecificationObj); // I see here different time of loading for SW 2011 and 2013, maybe this method was modified?
       var swModel = (ModelDoc2)swApp.ActiveDoc;
       var swConfMgr = (ConfigurationManager)swModel.ConfigurationManager;
      var activeConfig = (Configuration)swConfMgr.ActiveConfiguration;
      var rootComponent = (Component2)activeConfig.GetRootComponent();
      var numComponents = calcComponents(rootComponent, 1);
      int calcComponents(IComponent2 comp, long nLevel)
           int numComponents = 1;
           string sPadStr = " ";
           long i = 0;
           for(i = 0; i <= nLevel - 1; i++)
                sPadStr = sPadStr +  " ";
           var children = (object[])comp.GetChildren();
      for(i = 0; i < children.Length; i++)
                Component2 swChildComp = (SW.Component2)children[i];
                Debug.Print(sPadStr + "+" + swChildComp.Name2 + " <" + swChildComp.ReferencedConfiguration + ">");
      numComponents += calcComponents(swChildComp, nLevel + 1);     }
          return numComponents;
      Thanks in advance
