3 Replies Latest reply on Sep 13, 2013 2:17 AM by Victor B
    Macro building features in a loop doesn’t work
    Victor B
      Hello all
      I write a macro that takes coordinates of two ends of a cylinder and draw it by Sweep. The coordinates and the radius are in a text file. With the help of macro recording I found how to build it for one cylinder. Now I do this in a loop and get the following wonders:
      The first four cylinders are built normally.
      The fifth 3D sketch is drawn, but the extrusion not.
      The sixth 3D sketch is not drawn.
      If I try this several times, the Solid crashes.
      I am new in macroing for the Solid. What do I do wrong?
      Thank you
      Dim n As Integer
      Set Part = swApp.NewDocument("C:\Documents and Settings\All Users\Application Data\SolidWorks\SolidWorks 2010\templates\Part.prtdot", 0, 0, 0)
      swApp.ActivateDoc2 "Part1", False, longstatus
      Set Part = swApp.ActiveDoc
      'file reading
      Set objFSO = CreateObject("Scripting.FileSystemObject")
      Set objFile = objFSO.OpenTextFile("D:\My\OptimalDesign\Dropbox\TreeBot\MeasureArm\TreeRe\Apple11_10_13\Tree2.txt", 1)
      Dim s As String
      Dim a() As String
      Dim x, dx, y, dy, z, dz, r As Double
      'Branches
      s = objFile.ReadLine
      n = CInt(s)
      For i = 1 To n
          a = Split(s, "   ", -1, 1)
          x = CDbl(a(0))
          y = CDbl(a(1))
          z = CDbl(a(2))
          dx = CDbl(a(3))
          dy = CDbl(a(4))
          dz = CDbl(a(5))
          r = CDbl(a(6))
          'line
          Part.SketchManager.Insert3DSketch True
          Dim skSegment As Object
          Set skSegment = Part.SketchManager.CreateLine(x, y, z, x + dx, y + dy, z + dz)
          Part.SketchManager.Insert3DSketch False
          Part.ClearSelection2 True
          'plane
          boolstatus = Part.Extension.SelectByID2("Line1@3DSketch" & CStr(i), "EXTSKETCHSEGMENT", x, y, z, True, 0, Nothing, 0)
          boolstatus = Part.Extension.SelectByID2("Point1@3DSketch" & CStr(i), "EXTSKETCHPOINT", x, y, z, True, 1, Nothing, 0)
          Dim myRefPlane As Object
          Set myRefPlane = Part.FeatureManager.InsertRefPlane(2, 0, 4, 0, 0, 0)
          'circle
          boolstatus = Part.Extension.SelectByID2("Plane" & CStr(i), "PLANE", x, y, z, False, 0, Nothing, 0)
          Part.SketchManager.InsertSketch True
          Set skSegment = Part.SketchManager.CreateCircleByRadius(0, 0, 0#, r)
          'Sweep
          boolstatus = Part.Extension.SelectByID2("Sketch" & CStr(i), "SKETCH", x, y, 0#, False, 1, Nothing, 0)
          boolstatus = Part.Extension.SelectByID2("3DSketch" & CStr(i), "SKETCH", x, y, z, True, 4, Nothing, 0)
          Dim myFeature As Object
          Set myFeature = Part.FeatureManager.InsertProtrusionSwept3(False, False, 0, False, False, 0, 0, False, 0, 0, 0, 0, True, True, True, 0, True)
          'Hide plane
          Part.BlankRefGeom
          'Unhide line
          boolstatus = Part.Extension.SelectByID2("3DSketch" & CStr(i), "SKETCH", x, y, z, False, 0, Nothing, 0)
          Part.UnblankSketch
      Next
      Part.ViewZoomtofit2
