RPRoma Pas11/09/2013
hi, i'm trying to make a motor of an air compressor move.
see attachment.
i set the component properties of the dynamic part to flexible, but if i click 'move component' or just try to move the
motor by moving the connecting rod or crankshaft with the mouse by left clicking and dragging, it doesn't work.
if i attach the flexible assembly to the static assembly (with mates) at only one screw point, then i can still move the flexible parts (eventhough they will rotate also outside the static part then, but it seems to be working),
but as soon as i attach it on 2 screw points, nothing is able to move anymore.
"Selected component is fully defined. It cannot be moved."
what am i doing wrong?
if i remove some of the mates between the crankshaft and the bearing this also doesn't help. it seems to need some constraints.
if i move the crankshaft bearing from the dynamic assembly to the static assembly this also doesn't work.
please help!
best,
roma
