2 Replies Latest reply on Sep 11, 2013 9:28 PM by Vincent Li
    Macro to New-Save-Close a part, but still got a temp part doc in SWX without being closed?why
    Vincent Li
      Dear Masters,
      I record a macro with these steps  :
      1.new a part with a part template.
      2.save the file without doing any thing, just save the empty part doc to somewhere.
      3.close the part doc.
      then the macro is as below, and I edited it a little bit that I need it to save the part named "ABC.sldprt"
      Dim swApp As Object
      Dim Part As Object
      Dim boolstatus As Boolean
      Set Part = swApp.NewDocument("G:\Program Files\SolidWorks Corp\SolidWorks\lang\chinese-simplified\Tutorial\part.prtdot", 0, 0, 0)
      Set Part = swApp.ActiveDoc
      longstatus = Part.SaveAs3("E:\ABC.SLDPRT", 0, 2)
      Set Part = Nothing
      swApp.CloseDoc "ABC"
      when I run the macro, it do the thing I wanted , but leaving one thing that I do not understand:
      after the New-->Save-->Close the ABC.sldprt, the SW still contian a temp part doc there, and it named partXX, like we new a
      part, and SWX gives a temp name for the doc before we save it.
      What I need is making this temp part doc disappear after running the macro.
      regards
      Vincent
