0 Replies Latest reply on Sep 10, 2013 2:03 PM by Dan Hofstetter
    Flow sim API question - ApplyParametersFromFile
    Dan Hofstetter
      Hi all,
      Another Flow Sim API question.  According to the API help file, for FDAProject::ApplyParametersFromFile:  This method gets new parameter values from xml file.  I have successfully used FDAProject::ExportParametersToFile to save the flow project parameters to an XML file, and I can open that file for editing, but after saving it and trying ApplyParametersFromFile nothing seems to change.  Below is the section of the XML file I want to change:
      <FeatureNAME value="Initial Condition 1"/>
      <PS_Parameters index="8">
        <IsVisible value="1"/>
        <Name value="Hydrogen Sulfide"/>
        <ParameterID value="cb58563b-6365-4a43-9479-f03ffbaeddfe"/>
        <Type value="300"/>
        <Units value="32"/>
        <Value value="0.01"/>
        <ValueGreaterEqual value="0"/>
        <ValueType value="2"/>
      </PS_Parameters>
      I want to change <Value value> from "0.01" to "0.0001" but nothing seems to happen when I save the new XML file and run the following code:
      Sub ApplyParametersFromFile()
          Dim NCA As New NIKCommonApiLib.BaseApiObject
          Dim IA As NIKCommonApiLib.InteractiveApplication
          Dim MD As NIKCommonApiLib.ModelDoc
          Dim MC As NIKCommonApiLib.ModelConfiguration
          Dim FDA As NIKCommonApiLib.FDAProject
          retval = NCA.LoadProductAPI("Srac\Flow Simulation 2013\API SDK")
          Set IA = NCA.Attach2RunningObject
          Set MD = IA.ActiveDocument
          Set MC = MD.ActiveConfiguration
          Set FDA = MC.GetFluidDynamicAnalysisProject
          FDA.ApplyParametersFromFile "e:\new1.xml"
          NCA.UnloadProductAPI
      Can anyone help with this?
      Dan
