1 Reply Latest reply on Sep 10, 2013 12:32 PM by Simon Turner
    Insert Bend table Not working using solidworks API
    Vikas DC
      Trying to insert a bend table for a flat pattern view, Nothing happens when this macro is run.(only creates flat pattern view). Try to debug it , Crashes at line
      Set myBendTableAnnot = Fview.InsertBendTable(False, 0.1, 0.15, 1, "A", "C:\Users\Vikas\Documents\SOLIDWORKS DRAWINGS\BendTable.sldbndtbt")
      Not sure whats causing this, Please can anybody help
      ‘This macro will create a Flat pattern View and insert Bend table
      Option Explicit
      Dim swModel As ModelDoc2
      Dim swDrawing As DrawingDoc
      Dim filename As String
      Dim ext As String
      Dim fso As Scripting.FileSystemObject
      Dim longerrors As Long, longwarnings As Long
      Set fso = CreateObject("Scripting.FileSystemObject")
      Set swModel = swApp.ActiveDoc
      If swModel Is Nothing Then Exit Sub
      filename = swModel.GetPathName
      ' Find all files ending in .SLDPRT
      ext = UCase(Right(filename, 6))
      If ext <> "SLDPRT" And ext <> "SLDASM" Then Exit Sub
      Dim curfilename As String
      curfilename = Left(filename, Len(filename) - 7) & ".SLDDRW"
      ' Check whether file already exists
      If fso.FileExists(curfilename) Then
          If MsgBox(curfilename & " already exists. Overwrite?", vbYesNo + vbQuestion) = vbNo Then Exit Sub
      ' Get default template
      Dim template As String
      template = swApp.GetUserPreferenceStringValue(swDefaultTemplateDrawing)
      ' NewDocument templateName, paperSize, width, height. Paper Size, Width & Height if specified in template are redundant
      Set swDrawing = swApp.NewDocument(template, 0, 0, 0)
      If swDrawing Is Nothing Then
      MsgBox "Failed to create drawing"
      Exit Sub
      If (ext = "SLDPRT") Then
          swApp.OpenDoc6 filename, swDocPART, swOpenDocOptions_ReadOnly, "", longerrors, longwarnings
      Else: swApp.OpenDoc6 filename, swDocASSEMBLY, swOpenDocOptions_ReadOnly, "", longerrors, longwarnings
      ' Get sheet size
      Dim cursheet As sheet
      Dim sheetwidth As Double, sheetheight As Double
      Set cursheet = swDrawing.GetCurrentSheet
      1. cursheet.GetSize sheetwidth, sheetheight
      Dim view As view
      Dim vOutline As Variant, vPosition As Variant
      Dim viewWidth As Double, viewHeight As Double
      ' Insert the Flat Pattern View
      Dim Fview As view
      Dim ConfigName As String
      Dim HideBendLines As Boolean
      Dim LocX As Double
      Dim LocY As Double
      Dim LocZ As Double
      Dim FlipView As Boolean
      Dim value As view
      LocX = 0.2
      LocY = 0.1
      LocZ = 0
      HideBendLines = False
      ConfigName = "" 'DefaultSM-FLAT-PATTERN
      Set Fview = swDrawing.CreateFlatPatternViewFromModelView3(filename, ConfigName, LocX, LocY, LocZ, HideBendLines, False)
      'Insert Bend table for the flat pattern
      Dim swView As view
      Dim myBendTableAnnot As BendTableAnnotation
      Dim myBendTableFeat As BendTable
      Dim checkname As String
      Set myBendTableFeat = myBendTableAnnot.BendTable
      Debug.Print myBendTableFeat.GetFeature.Name
      Debug.Print "Starting tag: " & myBendTableFeat.StartingValue
      Debug.Print "swBendTableTagStyle_e option: " & myBendTableFeat.TagStyle
      Debug.Print "Number of bend table annotations: " & myBendTableFeat.GetTableAnnotationCount
      swModel.ClearSelection2 True
      'swApp.CloseDoc filename
      'swApp.CloseDoc curfilename
