I will state step by step what I have done and where I
encounter my problem
1. Select rectangle and draw and rectangle from the origion.
2. Give it dimensions 120 x 120 making it fully defined.
3. Click "Features" then "Extruded Boss/Bass"
4. I leave all the options as default except depth which I
set as 30mm
5. When I press the OK (tick) button i get the following
error msg
" The sketch contains a zero-length entity "
I am currently using SolidWorks 2006 SP0. I have also done
these steps on a previous version of SolidWorks (I think 2004) and
it worked perfectly. Attached is a screenshot with relevant
information to my problem.
If someone could help me out, I got no idea whats wrong here.
are you sure there is no other element in the sketch?
by the way is always possibile to extrude a wrong sketch
selecting
the area you want inside the last selection box "selected
contours"
4. I leave all the options as default except depth which I set as 30mm
5. When I press the OK (tick) button i get the following error msg
I am currently using SolidWorks 2006 SP0. I have also done these steps on a previous version of SolidWorks (I think 2004) and it worked perfectly. Attached is a screenshot with relevant information to my problem.
Regards
by the way is always possibile to extrude a wrong sketch selecting
the area you want inside the last selection box "selected contours"
I have 2006 SP4.1 and I have no problem to follow your steps.
