CJChris Johnson10/09/2013
Hello everyone,
I have a while loop that im using to prompt the user to select a face so that a sketch may be started on it.
everything works fine (Im able to spin the model around and make selections) when testing it in the vb editor but when I run it from within soldiworks using the "Run Macro" button I cannot spin the model around nor make selections. essentially SW locks up and the only way out is to end the process.
is there something wrong with the loop im using or the way im connecting to solidworks?
Option Explicit
Dim swApp As Object
Dim Part                                As Object
Dim boolstatus                          As Boolean
Dim longstatus                          As Long, longwarnings As Long
Dim swSelMgr                            As SldWorks.SelectionMgr
Const SelectedObjectCount = 1
Set Part = swApp.ActiveDoc
'Select the face to verify macro is workiing
        boolstatus = Part.Extension.SelectByID2("", "FACE", 0.304800000000057, 0.151591133586805, -3.67656190501293E-02, False, 0, Nothing, 0)
'Selection Setup
        Set swSelMgr = Part.SelectionManager
        Part.ClearSelection2 True
        MsgBox "Select a Face to to start a sketch on, then click OK."
        'frmSelectFace.Show
    'Wait while user selects a face and clicks OK
        While swSelMgr.GetSelectedObjectCount < SelectedObjectCount
        Wend
thank you in advance for the help
Chris
