Hi all,
My name is Samuel and for my Master degree, I am investigating the machining and processing of Carbon Composite Materials using a heat moving source such as a laser.
However, where I am stucked is how to applied it into Solidworks. In university, we are using the latest student edition.
My main question will be how to set up a heat moving source simulation in Solidworks.
If you can post the steps or a tutorial that will be great.
Thank you in advance.
Regards
Samuel
i think somoene asked this recently so you might want to check through the postings
with solidworks professional thermal analysis the best you can do is make a series of split lines and use curves to turn them on and off to simulate a moving laser.
