2 Replies Latest reply on Sep 9, 2013 11:11 AM by Jacob Cordingley
    Way to connect Custom Properties with MS ACCESS Table
    Parminder Singh
      Hi Guys!
      I’m struggling to link my Custom Properties with a table of MS Access
      Linking Means Pasting the details from Access to Custom Properties.
      For Eg: If I have a model No: 500 is open in solidworks , I need the codes that will search that Part Number in that table and update the corresponding Properties in Custom Properties.
      Please support.
      (Please find an attachment of the Pick and Database)
      Similar Code for Excel, but unable to connect with Access DB
      Dim excApp As Excel.Application
      Dim swCustPrpMgr As SldWorks.CustomPropertyManager
          Set excApp = GetObject(, "Excel.Application")
          Set swModel = swApp.ActiveDoc
          Set swCustPrpMgr = swModel.Extension.CustomPropertyManager("")
          Dim excRange As range
          Dim excSheet As Excel.Worksheet
          Set excSheet = excApp.ActiveSheet
          Set excRange = excSheet.range(excApp.Cells(1, 1), excApp.Cells(1000, 1))
          Dim searchRes As range
          Dim name As String
          Dim index As Integer
          Dim title As String
          title = swModel.GetTitle()
          index = InStr(title, ".")
          name = Left(title, IIf(index = 0, Len(title), index - 1))
          Set searchRes = excRange.Cells.Find(name)
          If Not searchRes Is Nothing Then
              LinkPrpToCell searchRes.row, 1, "EPMPartNumber"
              LinkPrpToCell searchRes.row, 2, "EPMPartName"
              LinkPrpToCell searchRes.row, 3, "EPMDescription"
              LinkPrpToCell searchRes.row, 4, "EPMMaterialReference"
              LinkPrpToCell searchRes.row, 5, "Density"
              LinkPrpToCell searchRes.row, 6, "EPMMaterial"
              Dim density As Double
              density = CDbl(excApp.Cells(searchRes.row, 5).value * 1000000)
              swModel.Extension.SetUserPreferenceDouble swUserPreferenceDoubleValue_e.swMaterialPropertyDensity, swUserPreferenceOption_e.swDetailingNoOptionSpecified, density
              MsgBox "Properties Updated"
          Else
              MsgBox "Failed"
        • Re: To link Custom Properties with MS ACCESS
          Josh Brady
          If you are working on your own program and have specific issues, please be more precise.
          If you are looking for a daily-use, production-ready macro I think what you are asking for is beyond the scope of free help on a forum.  This situation, while extremely useful, is also extremely boring to write.  If it's going to be used by multiple people, you need someone to work with you and make sure that the process works well with your workflow.  You probably need to pay someone to write it for you or research the billions of examples online of how to get custom properties and how to use ADO to interact with an Access database.
            Jacob Cordingley
            Looking at the database you supplied it just has the Materialand Density.  Are you using a SW Material  Database?
            I would like to know the main goal here .  Are you trying to import to or export from the DB, or something else?
            if your are exporting I've done that and can help you
            importing sould be about the same
