1 Reply Latest reply on Sep 8, 2013 7:39 PM by Artem Taturevych
    new on api worlds
    Daniel Cote
      Hi
      I make lot of API for Autocad in vs 2008 express.  Now I'am learnig the SOLIDWORKS API.
      I know how to programm with the VSTA vb.net.  But i like to use VISUAL STUDIO EXPRESS 2008 or 2010.   I see somewhere that with VSEXPRESS we can edit the code  while debugging it.
      My problem is I don't how to lauch Solidworks and load my DLL test it in debug mode.
      Someones have tutorial for that ????
      Also, in VSTA, I make a API to export  BOM ( ALREADY IN A DATAGRID )  to my MYSQL DB.  My code work in AUTOCAD but in SOLIDWORKS they work only for the first record.   At the second line, they start the SOLIDWORKSMACRO_STARTUP sub with the RUNRESULT = 4
      this the code i use
      ds.Tables(0).Clear()
      For i = 0 To DataGridView1.Rows.Count - 2
      ds.Tables(0).Rows.Add()
      Dim ITEM As String = DataGridView1.Rows(i).Cells("ITEM").Value()
      ds.Tables(0).Rows(0).Item(0) = ITEM
        Dim CMDBUILDER4 As New MySqlCommandBuilder(da)
      da.InsertCommand = CMDBUILDER4.GetInsertCommand()
      i = da.Update(ds.Tables(0))
