3 Replies Latest reply on Sep 10, 2013 7:32 PM by Jerry Steiger
    Unfold a solid shape? (not sheetmetal)
    First Last
      Hi all!
      Im designing a plywood recumbent bike frame, see attatched pictures for details, and i want to flatten the frame in order to transfer the design onto a sheet of plywood.
      Im going to build a jigg, steam the pre-cut plywood sheets and glue them under pressure to form the frame, so i need pretty exact blueprints.
      the frame is pretty much a arch, viewed from the side, with a radius of about 2700mm but the top view is  more complex, with a bunch of important mesurements.
      I have found a number of tutorials to unfold a sheetmetal part, but im unable to convert my part since i designed it in the "wrong" way.
      it is an extruded boss, on right plane, then boss-cut from top to shape it into a bike frame.
      im sure i cound figure out a way to sketch the design manually on the sheet, but it would be so much easier if i could print the actual design and transfer it onto the plywood.
      What i need is a flat surface extracted from the solid part that i can print, the top surface for instance.
      or do i have to learn sheetmetal part manufacturing and redesign the bike (again..)?
