I have a layer named Auxiliary View (Section and Detail Views as well) in which I have made the line type Thick/Thin, changed thickness, and it's color to blue. I have changed my Auxiliary View options in Document Properties to reflect this layer. With this layer selected I can create blue sketch lines, along with changing the entire part to blue. Also, if I make a "normal" Section or Detail View with the Aux Layer "On", it makes the section line blue - like it should...but, to save my life, I cannot get the Auxiliary View Section Line to change from black to blue when I create an Aux. Drawing View. I performed a Google search, but didn't come up with anyone else having this exact problem on the first few pages of results.
Section D-D and E-E were created with the same Layer, Auxiliary View. Auxiliary View Layer line color is blue, thin/thick, and .0098 thickness. As you can see in the last picture, the Auxiliary View Section Line is black instead of blue. I am not smoking crack....I swear!!!!! What gives? Anyone have any guesses as to what the problem or fix is?
