2 Replies Latest reply on Sep 4, 2013 4:44 PM by Chris Johnson
    Creating an Equation based on a measurement?
    Chris Johnson
      Hi All,,
      I must be doing something wrong and could use a little help.
      I want to measure the diameter of a selected edge and then use that dia. in an equation but its not working and I have no idea why.
      Here is the test code I set up to goof around with... see anything wrong?
      Option Explicit
          Dim swApp As Object
          Dim swmodel As Object
          Dim boolstatus As Boolean
          Dim Measure                     As Measure
          Set swmodel = swApp.ActiveDoc
          Set Measure = swmodel.Extension.CreateMeasure
      Measure.ArcOption = 0
      'PreSelect Edge and Run Macro
      'Measure and Store selected Edge Diameter for later use
                  boolstatus = Measure.Calculate(Nothing)
              Dim myMeasurement As Variant
                  myMeasurement = Measure.Diameter
                  swmodel.ClearSelection2 True
              Dim swEquationMgr As Object
                  Set swEquationMgr = swmodel.GetEquationMgr()
                      swEquationMgr.Add2 -1, """D1@Sketch2"" = myMeasurement - 0.5", True
      'this shows that the measurement exists..
          Debug.Print myMeasurement
          boolstatus = swmodel.ForceRebuild()
      T
      Thank you
      Chris
        • Re: Creating an Equation based on a measurement?
          Jason Kerns
          Option Explicit
              Dim swApp                   As SldWorks.SldWorks
              Dim swModel                 As SldWorks.ModelDoc2
              Dim swEquationMgr As SldWorks.EquationMgr
              Dim lValue   As Long
              Dim Eqstring As String
              Set swModel = swApp.ActiveDoc
              Set Measure = swModel.Extension.CreateMeasure
                      'swModel.ClearSelection2 True
                      Eqstring = """D1@Sketch1""" & " = " & myMeasurement - 0.5
                      Set swEquationMgr = swModel.GetEquationMgr()
                       lValue = swEquationMgr.Add2(-1, Eqstring, True)
              Debug.Print Eqstring
             swEquationMgr.EvaluateAll
              'boolstatus = swModel.EditRebuild3
              boolstatus = swModel.ForceRebuild()
