I am trying to manually add a weldmwnt profile and even though I have administrator priveledges on my machine when I try to save the file in the "C:\Program Files\SolidWorks Corp\SolidWorks\lang\english\weldment profiles\ansi inch\Wood" directory (\Wood is a folder I added) I get an error message telling me that I can't save there because I am not and administrator.
I have no idea what the problem is
Thanks for the help
-J-
There is a good chance that you don't have write access to that folder. Try it on a different drive other than C and check. If that works that talk to your IT/SW administrator.
If you're admin then make sure you're logged in as admin. Also disable UAC (in control panel) for putting those profiles there.
