0 Replies Latest reply on Aug 30, 2013 9:38 AM by Chris Johnson
    Is it possible to select the longest edge in an array of edges?
    Chris Johnson
      Hi All,
      after sending the edges of a selected face to an array, is it possible to then select the longest edge in that array for the purposes of finding and saving its persistent ID for later use?
      if it is possible I would like to select the longest edge, save its ID and then do the same for the second longest edge.
      Here is a snipet of the code that I do have working...but i have no idea if its possible to do what I want .
      'Select Surface-Cut1
              boolstatus = swModel.Extension.SelectByID2("SurfaceCut1", "BODYFEATURE", 0, 0, 0, False, 0, Nothing, 0)
          'Refine Selection to the face created by the Surface Cut (faces associated with specified feature)
                  Set swfeature = swSelMgr.GetSelectedObject6(1, -1)
                  vFaceArr = swfeature.GetFaces: If IsEmpty(vFaceArr) Then Exit Sub
                  For Each vFace In vFaceArr
                      Set swSelFace = vFace
                      Set swEntity = swSelFace
                      Set swFaceFeature = swSelFace.GetFeature
                      bRet = swEntity.Select4(True, swSelData)
                  Next
          'Get edges of face and put them in an array
              If Not swSelFace Is Nothing Then 'Check if Face is Selected
              vLoops = swSelFace.GetLoops
              swModel.ClearSelection2 True
              For i = 0 To UBound(vLoops)
              Set swLoop = vLoops(i)
              If swLoop.IsOuter() Then
              vEdges = swLoop.GetEdges
              For j = 0 To UBound(vEdges)
              Set EdgeEntity = vEdges(j)
              EdgeEntity.Select4 True, Nothing
              Next
              Next
      OH, By the way...the purpose of this is to programatically select the specifed edges (one at a time) so that a chamfer may be applied to each of them individually.
      thanks for you help!
      Chris
