1 Reply Latest reply on Aug 30, 2013 12:57 PM by Oleg Bezyaev
    Can i convert current vb.net solidworks project to C#.NET
    Yogesh Duggal
      We are currently using VB.NET for Project with Solid Works 2012, for some reasons we want to convert our Project from VB.NET to C#.
      I Want to know if there is any issues regarding Conversion and Do Solid Work 2012 gives API supports to C#.
      As far as i have seen is that Solid works 2012 has given only VB.NET Documentation but not for C#.
      We are Currently Converting our Project from VB to C# but having some issues in Solid Work Object
      This is the code :-
      VB :-   swApp = CreateObject("SldWorks.Application")
      C# : -  swAPP = (SldWorks)Activator.CreateInstance(Type.GetTypeFromProgID("SldWorks.Application"));
                Or swAPP = (SldWorks)Interaction.CreateObject("SldWorks.Application");
      But the Object that is Created does not have the "ActiveDoc" that is Available in VB.NET
      I am Attaching the Images for both Code Object.
      VB.NET
      But not Available in C#
      Please provide me link or Documents that gives supports for Solid Work 2012 with C#.
        • Re: Can i convert current vb.net solidworks project to C#.NET
          Oleg Bezyaev
          Hi Yogesh,
          but not for C#.
          This is not a true statement. Solidworks API reference contains many examples for C #. Each function is described in 3 languages. For example
          In your case code looks like this:
          C#
          object processSW = System.Activator.CreateInstance(System.Type.GetTypeFromProgID("SldWorks.Application"));
          SldWorks swApp = (SldWorks)processSW;
          IModelDoc2 swModel = swApp.IActiveDoc2;
          And swApp variable contains IActiveDoc2, it just is null. (see pic)
          And generally speaking, the VB and C # using the same NET library (Framework) and same API interfaces. Switch from one language to another should not cause difficulties.
