4 Replies Latest reply on Oct 4, 2013 9:54 AM by Hans Bekkers
    Components stay floating in assy after insertion by API
    Hans Bekkers
      Hi Everyone,
      The company I work for receives vast amounts of 3D CAD Data via IGS files. These IGS files normally are parts, which can be put together in an assembly and form a component together. In order to reduce the manual labour, I am now programming a macro which converts all IGS files in it's folder to SLDPRT's, starts an assy, inserts the new SLDPRT, then transforms the origin so the origin of the part lines up with the origin of the assembly, repeats this proces for all IGS files in it's folder and  saves and closes all documents. So far so good. All of this is working.
      But here comes the problem;
      It only fixes the first component which is inserted in the assy. The second (and all latter ones for that matter) stay floating. I have looked into the fixcomponent Method but I can't seem to get it to work properly. Who can help me out?
      PS: The code is still sloppy, I have quite some experience in Excel VBA, but these are my first endeauvours in SW, so be kind
      The code I have so far:
      Dim swApp           As Object
      Dim Part            As Object
      Dim boolstatus      As Boolean
      Dim longstatus      As Long
      Dim longwarnings    As Long
      Dim sFileName       As String
      Dim Path            As String
      Dim partFileName    As String
      Dim FixFileName     As String
      Dim openDocs        As Variant
      Dim currentModel    As Variant
      Dim swPartDoc       As PartDoc
      Dim swAssemblyDoc   As AssemblyDoc
      Dim swComp          As Component2
      Dim swMathUtil      As SldWorks.MathUtility
      Dim swXform         As SldWorks.MathTransform
      Set swApp = _
      Application.SldWorks
      Path = Left(swApp.GetCurrentMacroPathName(), InStrRev(swApp.GetCurrentMacroPathName(), "\"))
      sFileName = Dir(Path & "*.igs")
      Set Part = swApp.NewDocument("H:\SolidWorks\Common Data\VdB Assembly.asmdot", 0, 0, 0)
      swApp.ActivateDoc2 "Assem1", False, longstatus
      longstatus = Part.SaveAs3(Path + "Assy.SLDASM", 0, 2)
      Do Until sFileName = ""
              boolstatus = swApp.LoadFile2(Path + sFileName, "r")
              Set Part = swApp.ActiveDoc
              Dim myModelView As Object
              Set myModelView = Part.ActiveView
              myModelView.FrameState = swWindowState_e.swWindowMaximized
              longstatus = Part.ImportDiagnosis(True, False, True, 0)
              Part.ClearSelection2 True
              longstatus = Part.SaveAs3(Path + Part.GetTitle + ".SLDPRT", 0, 0)
              openDocs = swApp.GetDocuments()
              For Each currentModel In openDocs
                  If (currentModel.GetType = swDocumentTypes_e.swDocASSEMBLY) Then
                      Set swAssemblyDoc = currentModel
                  If (currentModel.GetType = swDocumentTypes_e.swDocPART) Then
                      Set swPartDoc = currentModel
                      partFileName = swPartDoc.GetPathName()
              Next
              Set swMathUtil = swApp.GetMathUtility
              Set swXform = swMathUtil.CreateTransform(Nothing)
              swComp.Transform2 = swXform
              swAssemblyDoc.EditRebuild3
              longstatus = swAssemblyDoc.SaveAs3(Path + "Assy.SLDASM", 0, 2)
              swApp.CloseDoc swPartDoc.GetTitle
              sFileName = Dir
      Loop
      swApp.CloseAllDocuments (True)
