on 30. Jan 2006 07:08 rickyhaden wrote:
> Actually i am facing a problem to draw inclined line at particular angle. what i
> do to draw such line. Suppose i has a base line and i has to draw inclined line
> with the base line at angle of 290.
After drawing the two lines pick "Smart Dimension" from the sketch toolbar, left click on both the base line & the second line. An angle dimension is shown with a small "Modify" dialog box. Move the cursor to position the angle dimension arc where you want it. Enter the angle you want the second line at and click on the green check-mark. The second line will rotate to the angle you typed in.
Hope that helps.
Hope that helps.
