Thanks Mike, but I had that unchecked already. I need a
system setting change and that takes you to the current document
settings. I am running 2006 and it doesn't work.
This is what I did in SW 2005:
Click on the "Tools" pulldown, then "Options". In the dialog
box left pane select "Relations/Snaps" under "Sketch". The dialog
box changes and a button labeled "Go to Document Grid Settings"
appears. Click on it. At the top of the new dialog box uncheck the
box for "Display Grid", then click on the "OK" button. From now on
when you draw in a sketch the grid won't (shouldn't) pop up. Wasn't
that easy? ;-) Hope it works for you, too.
Mike
Thanks anyway,
Ron
