I know there are some sprs's about this error but some one has a solution to model the attached part and obtain correct flat pattern for each configuration.
The only solution that I found is to add smart dimension on edge sketch, but if the part has many edge flanges must add dimension on each one!!!
No one is bothered by this sw 2013 sheet metal bug?! I'm the only one?
