1 Reply Latest reply on Dec 7, 2013 7:00 PM by Yong Ning
    How to use FeatureByName in Traverse Assembly of subFeature?
    Yong Ning
      FeatureByName
          Dim swApp                   As SldWorks.SldWorks
          Dim swModel                 As SldWorks.ModelDoc2
          Dim swAssy                  As SldWorks.AssemblyDoc
          Dim swSelMgr                As SldWorks.SelectionMgr
          Dim swComp                  As SldWorks.Component2
          Dim swFeat                  As SldWorks.Feature
          Dim i                       As Long
          Dim bRet                    As Boolean
          Set swModel = swApp.ActiveDoc
          Set swAssy = swModel
          Set swComp = swSelMgr.GetSelectedObjectsComponent(1)
          Set swFeat = swAssy.FeatureByName(swComp.Name2): Debug.Assert Not swFeat Is Nothing
          Debug.Print swFeat.Name
        • Re: How to Traverse Assembly of subFeature ?
          Yong Ning
          Help me
          select cc-1/dd-1(cc.sldasm/dd.sldprt)
          Set swFeat = swAssy.FeatureByName("cc-1/dd-1") → result is false.
          https://forum.solidworks.com/message/329078#329078
          Private Sub TraverCompFeat()
            Dim SwAssy As AssemblyDoc, SwFeat As Feature
            Dim Str, bRet As Boolean, sFileName
            Set SwAssy = Application.SldWorks.ActiveDoc
            'Debug.Print SwAssy.GetTitle
            ''E:\MyWorkSummary\BESmodel\卧式储罐\DN2100-4000\Shell.SLDPRT
            'sFileName = "E:\MyWorkSummary\BESmodel\卧式储罐\贮罐V=50 Dn=2600\壳体Dn2600×26_L=8400.SldPrt"
            Set oDic = Nothing
            Set SwFeat = SwAssy.FirstFeature
            Do While Not SwFeat Is Nothing
              If SwFeat.GetTypeName = "Reference" Then
                Str = SwFeat.name
                Str = Left(Str, InStrRev(Str, "-") - 1)
                If Not oDic.Exists(Str) Then
                  oDic(Str) = ""
                  If Str Like "*Shell*" Then
                    Debug.Print Str, SwFeat.GetTypeName
                    SwFeat.Select False
                    bRet = SwAssy.ReplaceComponents(sFileName, "", True, True)
                    Debug.Print bRet
                SwFeat.Select False
              Set SwFeat = SwFeat.GetNextFeature
            Loop
             Dim oDic As New Dictionary
             Dim swModel As SldWorks.ModelDoc2, vModel As ModelDoc2
             Dim swChildComp As SldWorks.Component2
             Dim vChildComp As Variant
             Dim boolstatus As Boolean
             Dim ii, Str, sFileName, Path: Path = "D:\Backup\我的文档\aa\"
             Dim swSelMgr As SelectionMgr, swFeat As Feature
              vChildComp = swAssy.GetComponents(False)
              For ii = 0 To UBound(vChildComp)
                 Set swChildComp = vChildComp(ii)
                 Set vModel = swChildComp.GetModelDoc
                 If Not vModel Is Nothing Then
                    Str = vModel.GetTitle
                      oDic(Str) = ""
                      Debug.Print ii, Str
                      boolstatus = swChildComp.Select3(False, Nothing)
                      sFileName = Str
                      If ii = 0 Then
                        sFileName = Path & "a.sldasm"
                        bRet = swAssy.ReplaceComponents(sFileName, "", True, True)
              Next ii
          See Attatch file .
          Private Sub fdsafdsafdsafd()
             Dim Wk As Workbook, tmpPath, modelPath
             Set Wk = connectXls
             tmpPath = Wk.Path & "\temp"
             modelPath = Wk.Path & "\baseModel"
              Dim Fso As Object
              'On Error Resume Next
              Set Fso = CreateObject("Scripting.FileSystemObject")
              Fso.CopyFile modelPath & "\*.*", tmpPath
              Dim swApp As SldWorks.SldWorks, SwDraw As DrawingDoc
              Dim fileerror As Long, filewarning As Long, FileName
              FileName = tmpPath & "\Tank.SldDrw"
              'Set SwDraw = swApp.OpenDoc6("C:\360高速下载\卧式储罐\Temp\Tank.SldDrw", 3, 0, "", longstatus, longwarnings)
              Debug.Print FileName
              'Set SwDraw = swApp.OpenDoc6(FileName, 3, 0, "", longstatus, longwarnings)
              Set SwDraw = SwOpenFile(swApp, FileName)
