In the edit weldment interface, on a rare occasion, when I switch between "groups" of weldment, and click "locate profile," and not move the "camera" at all, I can then select a point and click on the "alignment" box and it works.
However, this does not always work. And I cannot figure out why I essentially can't select points.
I have tried the "filter vertices" option and it does nothing,
And it also will allow me to select lines, even with the filter vertices option. This is confusing.
I read something about video drivers being an issue, so I updated them but nothing changed.
I have a Lenovo W530 with a K2000 video card
Regarding my point selection issue,
I've found out that when (often) I can't select points, I can just move the camera a bit then click Locate Profile until it lets me. I still have some rather unique bug, it seems; but at least I have a quickly repeatable workaround for it, now.
Philip Lewis,
I see that I have been using the Alignment box incorrectly, now. Thanks. I thought it was the box that changes the "point" that the path "pierces" the profile sketch. What you showed makes so much more sense.
