Hi everyone, I'm simulating the mechanism of an AR-15 rifle in SW Motion Analysis 2013 SP4 on a fast university computer (3.04GHz i7, eight cores, 8Gb RAM...). The model is fairly complicated, but after applying all desired mates, I can slide the bolt carrier back and forth, rotate and slide the bolt along/about its long axis, and move the buffer back and forth in the assembly view. In motion, I'm first attempting a simulation of the bolt being locked (lugs pressed against the barrel extension, therefore the bolt should not move) with a force applied to the bolt face and a contact between the bolt and bolt extension, (just to make sure everything works before going to the trouble of setting up a more complicated motion study). The events in an AR's firing cycle are timed in small fractions of a second, so my simulation lasts for ~26ms with 25,000fps. Looking at the mates list in the motion study view, I see '0 redundancies'; however, when I attempt to run this simulation, I get the following error:
"Initial Conditions Error:
The model contains incompatible redundant constraints, i.e., constraints
that are contradictory and cannot be simultaneously satisfied.
Try to eliminate some or all of the redundant constraints in your model."
I then went into the simulation options window and chose 'replace redundant mates with bushings'. I got the following error when I tried to run it:
Errors found parsing command. Command ignored. |
Simulation can not continue." |
I've searched the web for any explanation of these problems, but no luck.
The model is so large I'm going to upload 2 ZIP files; if you want to see it, just extract both into the same directory and then open "Rifle.SLDASM".
Thanks in advance!
I was able to get the simulation to run when I went through the mates and deleted one that was based on sketch elements on different parts (eg. each sketch had a line fixed to its respective part, and the sketch lines were mated to be parallel). I have used such mates in other motion studies for other projects, however, so perhaps it was the complexity of the model that caused these errors. Note that I tried importing the model into ADAMS (despite its nightmarish interface), but this mate caused the ADAMS simulation to fail as well.
