4 Replies Latest reply on May 25, 2017 6:18 AM by Yong Ning
    Have dimension → how to set DisplayDimension
    Yong Ning
      Known Dim swDispDim  As SldWorks.DisplayDimension
         Set swAnn = swDispDim.GetAnnotation
         Set swDim = swDispDim.GetDimension
          Dim swDim                       As SldWorks.Dimension
          Dim swAnn                       As SldWorks.Annotation
      Set swDispDim = swView.GetFirstDisplayDimension5
      My question
          Set swDim = swModel.Parameter("D1@Extrude1")
      How to set SldWorks.Dimension→SldWorks.DisplayDimension
        • Re: Have dimension → how to set DisplayDimension
          Yong Ning
          For example code.
          Have Dimension → How to set Displaydimension
          Option Explicit
              Dim swApp                       As SldWorks.SldWorks
              Dim swModel                     As SldWorks.ModelDoc2
              Dim vConfigNames                As Variant
              Dim vValue                      As Variant
              Set swModel = swApp.ActiveDoc
              Debug.Assert Not swDim Is Nothing
              Debug.Print "File = " & swModel.GetPathName
              Debug.Print "  FullName = " & swDim.FullName
              Debug.Print "  Name = " & swDim.Name
              vConfigNames = swModel.GetConfigurationNames
              vValue = swDim.GetSystemValue3(swThisConfiguration, (vConfigNames))
              Debug.Print "  SystemValue = " & vValue(0) * 1000#; "" & " mm"
              Artem Taturevych
              Despite it is not ideal solution but I do not see any other possible ways to do this (apart traversing):
                  If swModel.Extension.SelectByID2(swDim.GetNameForSelection(), "DIMENSION", 0, 0, 0, False, 0, Nothing, 0) Then
                      Set swDispDim = swSelMgr.GetSelectedObject6(1, -1)
              ____________________________________________________
              Regards,
              Artem Taturevych, Application Engineer at Intercad (Australia)
              translationXpert – add-in to translate SolidWorks models
              myIntercad an integrated tool for SolidWorks Professionals
              LinkedIn SolidWorks API Education Group
                  Yong Ning
                  Thank your tip.
                  2013 SolidWorks API Help - Get Feature Type and Name Example (VBA)
                  http://help.solidworks.com/2013/English/api/sldworksapi/get_feature_type_and_name_example_vb.htm
                  ' Get the feature's type and name
                  featName = swFeat.GetNameForSelection(featType)
                  swModelDocExt.SelectByID2 featName, featType, 0, 0, 0, True, 0, Nothing, 0
                  Sub ll()
                    Dim SwDraw As DrawingDoc
                    Set SwDraw = Application.SldWorks.ActiveDoc
                    Dim SwDisp As DisplayDimension, SwDim As Dimension
                      Set SwDim = SwDraw.Parameter("D1@草图1")
                  Debug.Print Not SwDim Is Nothing
                  Debug.Print
                      If Not SwDim Is Nothing Then
                      tmp = SwDraw.Extension.SelectByID2(SwDim.FullName, "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
                      Debug.Print tmp
                      SwDraw.EditDelete
                    Dim swApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
                    Dim vModel As ModelDoc2
                    Dim Arr, Arr1, oArr, oArr1, Rng As Range, Sht As Worksheet
                    Dim FileName, Str, Path
                    Set swApp = Application.SldWorks  ''
                    swApp.SetUserPreferenceToggle 249, False
                    Set SwDraw = swApp.ActiveDoc
                    FileName = Left(SwDraw.GetPathName, InStr(FileName, "卧式储罐") + 4) & "Horizontal Tank.xls"
                    Set Sht = OpenXls(FileName).Sheets("材料表")
                    Str = SwDraw.GetPathName
                    'Debug.Print Str, Sht.name
                    savePath = Left(Str, InStrRev(Str, "\"))
                    Set Rng = Sht.Range("A5:A" & Sht.Range("A65536").End(3).Row)
                    For ii = 1 To Rng.Rows.Count
                      If Rng(ii, 1) <> "" Then
                        Set SwModel = swApp.GetOpenDocumentByName(savePath & Rng(ii, 21))
                        'Debug.Print SwModel.GetTitle
                        SwDwg swApp, SwModel, Sht, Rng(ii, 1)
                        SwModel.ForceRebuild3 False
                    Next ii
                    Dim SwDim As Dimension, SwDim1 As Dimension, SwView As View
                    With SwDraw
                       Set SwView = .GetFirstView
                       Set SwView = SwView.GetNextView
                       Str = "RD5@" & SwView.name
                       Set SwDim1 = SwDraw.Parameter(Str)
                       Str = "D7@草图1"
                       Set SwDim = SwDraw.Parameter(Str)
                       'Debug.Print SwDim.FullName, SwDim.Value, SwDim1.FullName, SwDim1.Value
                       SwDim.Value = SwDim1.Value
                       Str = "RD3@" & SwView.name
                       Str = "D5@草图1"
                       SwDim.Value = SwDim1.Value - 150
                       SwDraw.ForceRebuild3 False
                       For ii = 1 To 10
                         Set SwDim = SwDraw.Parameter("D" & ii & "@草图1")
                            Debug.Print tmp
                            SwDraw.EditDelete
                      Next ii
                       '.Save2 False
                    End With
                    swApp.SetUserPreferenceToggle 249, True
                  Sub ll()
                     Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, Str
                      Set SwApp = Application.SldWorks
                      Set SwModel = SwApp.ActiveDoc
                      Set SwSelMgr = SwModel.SelectionManager
                      Dim DispDim As DisplayDimension, SwDim As SldWorks.Dimension, SwDim1 As Dimension
                      Set SwDim = SwModel.Parameter("TH_d@CutHoleSketch")
                      If SwModel.Extension.SelectByID2(SwDim.FullName, "DIMENSION", 0, 0, 0, False, 0, Nothing, 0) Then
                          Set swDispDim = SwSelMgr.GetSelectedObject6(1, -1)
                           Str = 64 & "-<MOD-DIAM>"
                           swDispDim.SetText 1, Str
                           swDispDim.SetText 4, "配M螺柱"
                           Debug.Print swDispDim.GetText(1), swDispDim.GetText(4)
                  Sub lll()
                    Dim SwApp As SldWorks.SldWorks, SwModel As ModelDoc2, SwDraw As DrawingDoc
                      Set SwApp = GetObject(, "SldWorks.Application")
                      Set SwDraw = SwModel
                    Dim SwSelMgr As SelectionMgr
                    Dim DispDim As DisplayDimension, SwDim As Dimension, SwAnn As Annotation
                      Set DispDim = SwSelMgr.GetSelectedObject6(1, -1)
                      With DispDim
                        'Debug.Print .HorizontalJustification
                        Debug.Print .GetUseDocBrokenLeader
                        .SetBrokenLeader2 False, swBrokenLeaderHorizontalText
                      End With
                      Yong Ning
                      Private Sub del2()
                              SwDraw.InsertModelAnnotations3 0, 1736728, True, True, True, True
                              SwModel.ClearSelection2 True
                          Dim Xls As Excel.Application, Rng As Range
                              Set Xls = GetObject(, "Excel.Application")
                              Set Rng = Xls.Selection
                              Debug.Print Rng.Address
                          Dim SwView As View, SwAnn As Annotation
                          Dim SwDispDim As DisplayDimension, SwDim As Dimension
                              Set SwView = SwDraw.GetFirstView
                              Do While Not SwView Is Nothing
                                  Set SwDispDim = SwView.GetFirstDisplayDimension
                                  Do While Not SwDispDim Is Nothing
                                          Set SwAnn = SwDispDim.GetAnnotation
                                          Debug.Print SwAnn.GetName
                                          'SwAnn.Select True
                                          Set SwDispDim = SwDispDim.GetNext
                                  Loop
                              Loop
                                  Set SwDim = SwModel.Parameter(Rng(ii, 1))
                                  Stop
                                  tmp = SwDraw.Extension.SelectByID2(Rng(ii, 1), "DIMENSION", 0, 0, 0, True, 0, Nothing, 0)
                                  Stop
                      Debug.Print SwDim.FullName, tmp
                              Next ii
                              'SwModel.EditDelete
                      Private Sub del3()
                                              If SwDim.FullName = SwDispDim.GetDimension.FullName Then
                                                  GoTo Here
                                          Next ii
                                          SwAnn.Select True
                      Here:
                                  Loop
                              Loop
                      Stop
                              SwModel.EditDelete
