1 Reply Latest reply on Aug 27, 2013 11:09 AM by Pierre Vergneault
    Is It possible to edit custom file properties (PartNo) using a Macro?
    Jason Turner
      Hello Everybody,
      I'm trying to change the part numbering system of a large part-database and I want to know if anyone knows of a "File.Properties.Custom.PartNo" object/property/method (or anything like that) that I can manipulate within a module.
      Thanks for your help in advance.
      -J-
        • Re: Is It possible to edit custom file properties (PartNo) using a Macro?
          Pierre Vergneault
          Here is a code to assign the same value to each custom property. I hope it will help
          Dim CustPropMng As SldWorks.CustomPropertyManager
          Dim LeComposant As ModelDoc2
          Dim ConfigName as String
          Dim CustPropNames As Variant
          Set LeComposant = ......................
          Set CustPropMng = LeComposant.Extension.CustomPropertyManager(ConfigName)
          CustPropNames = CustPropMng.GetNames
          For J = 0 To UBound(CustPropNames)
                        LeComposant.CustomInfo2(ConfigName, CustPropNames(J)) = "Your Value"
                        msgbox CustPropNames(J)
          next J
          Pierre
