0 Replies Latest reply on Aug 23, 2013 6:45 AM by Sanjay Phadke
    get selection for blocks & lines in drawing
    Sanjay Phadke
      Dear All,
      I am trying to get the information after selection of  many blocks & delete those on line
      How can I get the each block info & line info
      each block has specific attributes
      I want to delete those blocks only whose attribute is "test"
      my code is as below
      Dim selCount As Integer
          selCount = selMgr.GetSelectedObjectCount2(-1)
          selCount = selCount - 1
          ReDim obj(selCount) As Object
          Dim i As Integer
          For i = 0 To selCount
              Set obj(i) = selMgr.GetSelectedObject6(i + 1, -1)
                if  swselmgr.GetSelectedObjectType(1) = 114 then
                      For k = 0 To UBound(vNote)
                         Set swNote = vNote(k)
                         If swNote.TAGNAME = "test" Then
                             swdoc_DeleteSelectionPreNotify
                     Next k
             end if
          Next
      Sanjay Phadke
