Good evening,
I have a problem with a simulation I'm trying to do. The model isn't stable and I don't know why. The structure is 11.5m x 1.23m and the force applied is in N/m. No rotation is blocked. Y translations are blocked on each of the four extremities of the structure, X translations are blocked on the extremities of one side of the structure and Z translations are blocked for one extremity.
I have done a similar simulation with a different structure, and Solidwork was able to compute it no problem. Any clue?
Thank you
Use soft springs or extra fixes restraints to figure out where you're missing contact or connectors.
We recommend in out training to start small. Add one part at a time with a gravity load till you have the whole structure. If you run into an issue, you'll know where it happened.
