8 Replies Latest reply on Dec 4, 2013 12:39 PM by Frederick Moor
    swVBAServer has stopped working
    Glenn McAfee
      SolidWorks Premium (x64) 2013 SP 4
      Windows 7 Enterprise (x64)
      HP Z400 workstation w/NVIDIA Quadro FX 4800
      Of all the machines upgraded from SW2012 to SW2013, this one machine is displaying the error message (at SolidWorks startup) "swVBAServer has stopped working".  The only option is to "Close Program".  It comes up several times, before SolidWorks finishes launching.  I have uninstalled and reinstalled, both from our administrative image, and directly from the SolidWorks website.  Most recently, I uninstalled and selected to remove registry entries from the Advanced Options.
      Suspecting a profile issue, I logged on as myself, and I still get the same error message.
      The event log (Application Log) on that machine reported the following:
      Faulting application name: swvbaserver.exe, version: 21.4.0.70, time stamp: 0x51d8dedf
      Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
      Exception code: 0xc0000005
      Fault offset: 0x00000000
      Faulting process id: 0xfd0
      Faulting application start time: 0x01ce9f50b238e872
      Faulting application path: C:\Program Files\SolidWorks Corp\SolidWorks\swVBAServer\swvbaserver.exe
      Faulting module path: unknown
      Report Id: eff3bb5a-0b43-11e3-adf4-78acc098e513
      Accorting to the user at that station, no other new software has been installed.  There is only one copy of swvbaserver.exe on that machine (in C:\Program Files\SolidWorks Corp\SolidWorks\swVBAServer\).  I checked the size and timestamp of swVBAClient.tlb, swvbaserver.exe and swVBAServer.tlb against mine, and they match.
      The only cases of this problem I can fine on the Internet, either point to MS Office 2007, or the symptoms don't quite match.  We are running MS Office 2010, and that hasn't changed for the past year - short of any security updates.  The knowledge base here reportes it for SW2008 and SW2010, but that information was not helpful.
      I'm open for suggestions.
        • Re: swVBAServer has stopped working
          Dan Miel
          Glenn,
                      I have had this message a few times but it is not consistent on my machine. I have start the Task Manager (I usually right-click in the windows Task bar) and there will be two swvbserver.exe processes running. I select the one that is not running and SolidWorks then continues booting.
          I know this is a workaround but it has only happened a few times to me.
          Dan Miel
          SW 2013 SP04
              Glenn McAfee
              I appreciate that, but in this case, there is only one instance of the task running. (until it dies, of course)
                  Dan Miel
                  Glenn,
                  It just happened to me again and when I opened the Task Manager the was only one swvbaserver running so I Ended the Process and SolidWorks loaded. I guess there doesn’t need to be two of them running. I have attached a picture of the Task Manager.
                  Dan
                      Glenn McAfee
                      Since this particular PC is in our machine shop (no design work being done), I uninstalled SolidWorks and left eDrawings loaded, so that he can at least view and print drawings.  He will be mostly using Delcam products on that box.
                      My focus has changed to another PC (just upgraded from 2012 to 2013), which randomly comes up with "Failed to save document", no other information, then progresses to a scenario, where the save-as function takes on a life of its own and uses the file name of the last part opened, overwriting the existing file!  No confirmation to overwrite.
                      Many of our design engineers are becoming more and more disillusioned with SolidWorks (especially 2013) and are migrating to PowerShape.  That product, or another similar product may become the platform of choice here at Nike.  Not my call.
                      Next week, I will pursue the swvbaserver problem again, just in case it rears its ugly head on another PC.
                      Thanks for the input.
                          Jon Anders Osterud
                          Hi Glenn, did you ever find out what caused the swvbaserver.exe problems? I have the exact same problem with a customer's computer right now. I noticed a difference from my setup: 1. When SolidWorks starts, the vba 7.1 installer starts simultaneously, every time. 2. After exiting SolidWorks, the swvbaserver.exe process hangs, and a new one starts when loading SolidWorks again resulting in multiple swvbaserver.exe processes running. (on my setup the swvbaserver process stops after exiting SolidWorks).
                          A tip for the failed to save problem I picked up in another thread: Try excluding SolidWorks file types (.SLDPRT, .SLDDRW and .SLDASM) from your anti-virus program. I'm running tests with this on several machines now to see if this helps as we also get a lot of reports of this error in 2013.
                    Frederick Moor
                    I am having the same problem that Glenn describes.
                    At application startup, Initializing VBA fails.  Once the app is started, any action causes the same error message Glenn receives and the same content is in my event viewer.
                    i7-3960x
                    ASUS Rampage Extreme IV
                    32GB
                    SSD
                    AMD FirePro V4900
                    Win8.1 Pro x64
                    Solidworks 2013 SP05 Student Edition
                    Office 2013 Professional Plus x64
                    All drivers and software are current.
                    <update>
                    did a complete uninstall of all solidworks
                    removed all references to solidworks from the registry
                    just for grins, repaired Office
                    reinstalled video drivers
                    reinsalled SW.
                    same condition.  Initializing VBA fails during Solidworks startup and the swVBAServer has stopped working error is frequent.
                    Problem Event Name:APPCRASH
                      Application Name:swvbaserver.exe
                      Application Version:21.5.0.76
                      Application Timestamp:524b2c5d
                      Fault Module Name:swvbaserver.exe
                      Fault Module Version:21.5.0.76
                      Fault Module Timestamp:524b2c5d
                      Exception Code:c000041d
                      Exception Offset:0001c28c
                      OS Version:6.3.9600.2.0.0.256.48
                      Locale ID:1033
                      Additional Information 1:256d
                      Additional Information 2:256dec86773cc1c7970adcd62b5869ba
                      Additional Information 3:8bf4
                      Additional Information 4:8bf4c50c7d76051b2f20f8ab1e61c494
                    Message was edited by: Frederick Moor
                        Frederick Moor
                        Because it seems to matter somehow, here are the contents of my HKEY_CURRENT_USER\Software\Microsoft\VBA branch
                        Key Name:          HKEY_CURRENT_USER\Software\Microsoft\VBA
                        Class Name:        <NO CLASS>
                        Last Write Time:   11/28/2013 - 11:47 PM
                        Key Name:          HKEY_CURRENT_USER\Software\Microsoft\VBA\7.1
                        Key Name:          HKEY_CURRENT_USER\Software\Microsoft\VBA\7.1\Common
                        Last Write Time:   12/3/2013 - 12:06 AM
                        Value 0
                          Type:            REG_SZ
                          Data:            8 28 180 960 1
                        Value 1
                          Type:            REG_SZ
                          Data:            0 0 0 0 1
                        Value 2
                          Type:            REG_SZ
                          Data:            0
                        Value 3
                          Type:            REG_BINARY
                          Data:
                        00000000   02 00 4c 01 05 00 08 00 - 08 00 1f 00 f8 09 70 05  ..L.........ø          p.
                        00000010   ff 02 01 01 08 00 1f 00 - bc 00 70 05 ff 02 00 01  ÿ.......¼.p.ÿ...
                        00000020   08 00 1f 00 bc 00 1b 02 - 05 00 00 01 08 00 21 02  ....¼.........!.
                        00000030   bc 00 70 05 01 00 00 01 - c2 00 1f 00 f8 09 70 05  ¼.p.....Â...ø          p.
                        00000040   ff 02 00 01 c2 00 1f 00 - f8 09 70 05 ff 02 01 01  ÿ...Â...ø          p.ÿ...
                        00000050   c2 00 1f 00 f8 09 70 05 - 00 00 00 01 bb 03 5e 00  Â...ø          p.....».^.
                        00000060   fc 03 fc 02 06 00 00 00 - d3 00 af 01 09 03 32 02  ü.ü.....Ó.¯.          .2.
                        00000070   ff 03 01 00 d3 00 af 01 - 09 03 32 02 04 00 00 00  ÿ...Ó.¯.          .2.....
                        00000080   93 01 af 01 09 03 32 02 - 03 00 00 00 d3 00 af 01  ..¯.          .2.....Ó.¯.
                        00000090   09 03 32 02 02 00 00 00 - 21 00 72 01 6c 02 12 02            .2.....!.r.l...
                        000000a0   ff 03 01 00 21 00 72 01 - e8 00 12 02 04 00 00 00  ÿ...!.r.è.......
                        000000b0   ee 00 72 01 a9 01 12 02 - 03 00 00 00 af 01 72 01  î.r.©.......¯.r.
                        000000c0   6c 02 12 02 02 00 00 00 - f8 02 81 00 ac 03 01 01  l.......ø...¬...
                        000000d0   05 00 00 00 59 00 30 02 - 0d 01 4b 03 01 00 00 00  ....Y.0...K.....
                        000000e0   3a 03 bc 00 79 03 1f 02 - 06 00 00 00 16 00 16 00  :.¼.y...........
                        000000f0   d9 01 c4 00 04 00 01 00 - 2c 00 2c 00 eb 01 e3 00  Ù.Ä.....,.,.ë.ã.
                        00000100   03 00 01 00 42 00 42 00 - 3b 02 f7 00 02 00 01 00  ....B.B.;.÷.....
                        00000110   00 00 00 00 00 00 00 00 - 08 00 00 00 58 00 57 00  ............X.W.
                        00000120   37 01 ff 01 01 00 01 00 - 00 00 00 00 00 00 00 00  7.ÿ.............
                        00000130   06 00 01 00 6e 00 6e 00 - 7f 01 52 01 05 00 01 00  ....n.n...R.....
                        00000140   00 00 00 00 00 00 00 00 - 00 00 01 00              ............
                        Value 4
                          Type:            REG_SZ
                          Data:            1
                        Value 5
                          Type:            REG_BINARY
                          Data:
                        00000000   00 00 00 00 07 00 00 00 - 47 65 6e 65 72 61 6c 00  ........General.
                        00000010   ff ff ff ff ff ff ff ff -                          ÿÿÿÿÿÿÿÿ
                        Value 6
                          Type:            REG_SZ
                          Data:            0
                        Value 7
                          Type:            REG_SZ
                          Data:            0
                        Value 8
                          Type:            REG_BINARY
                          Data:
                        00000000   68 00 00 00 01 01 00 00 - 00 00 00 00 1e 00 01 00  h...............
                        00000010   00 00 02 01 0b 00 00 80 - 00 00 08 01 00 01 00 00  ................
                        00000020   16 00 08 4d 00 65 00 6e - 00 75 00 20 00 42 00 61  ...M.e.n.u. .B.a
                        00000030   00 72 00 01 01 01 00 00 - 00 ff ff 00 00 fd ff 32  .r.......ÿÿ..ýÿ2
                        00000040   00 32 00 58 02 5a 00 00 - 00 00 00 03 01 00 0a 32  .2.X.Z.........2
                        00000050   75 00 00 00 00 03 01 00 - 00 00 00 01 80 00 00 03  u...............
                        00000060   01 00 0a 33 75 00 00 00 - 00 03 02 00 00 00 00 02  ...3u...........
                        00000070   80 00 00 03 01 00 0a 34 - 75 00 00 00 00 03 03 00  .......4u.......
                        00000080   00 00 00 03 80 00 00 03 - 01 00 0a 35 75 00 00 00  ...........5u...
                        00000090   00 03 04 00 00 00 00 04 - 80 00 00 03 01 00 0a 36  ...............6
                        000000a0   75 00 00 00 00 03 05 00 - 00 00 00 05 80 00 00 03  u...............
                        000000b0   01 00 0a d5 75 00 00 00 - 00 03 06 00 00 00 00 06  ...Õu...........
                        000000c0   80 00 00 03 01 00 0a 3c - 75 00 00 00 00 03 07 00  .......<u.......
                        000000d0   00 00 00 07 80 00 00 03 - 01 00 0a 37 75 00 00 00  ...........7u...
                        000000e0   00 03 08 00 00 00 00 08 - 80 00 00 03 01 00 0a 56  ...............V
                        000000f0   75 00 00 00 00 03 09 00 - 00 00 00 09 80 00 00 03  u.....          ....          ....
                        00000100   01 00 0a 39 75 00 00 00 - 00 03 0a 00 00 00 00 0a  ...9u...........
                        00000110   80 00 00 03 01 00 0a 3a - 75 00 00 00 00 03 0b 00  .......:u.......
                        00000120   00 00 00 30 00 00 00 02 - 01 ff ff 2f 80 00 00 00  ...0.....ÿÿ/....
                        00000130   00 00 00 00 00 12 00 08 - 53 00 74 00 61 00 6e 00  ........S.t.a.n.
                        00000140   64 00 61 00 72 00 64 00 - 01 01 01 01 00 00 ff ff  d.a.r.d.......ÿÿ
                        00000150   00 00 fd ff 32 00 6e 00 - 58 02 96 00 2f 00 00 00  ..ýÿ2.n.X.../...
                        00000160   02 01 ff ff 30 80 00 00 - 00 00 00 00 00 00 12 00  ..ÿÿ0...........
                        00000170   04 45 00 64 00 69 00 74 - 00 04 00 01 02 00 00 ff  .E.d.i.t.......ÿ
                        00000180   ff 00 00 fd ff 32 00 aa - 00 58 02 d2 00 30 00 00  ÿ..ýÿ2.ª.X.Ò.0..
                        00000190   00 02 01 ff ff 31 80 00 - 00 00 00 00 00 00 00 12  ...ÿÿ1..........
                        000001a0   00 05 44 00 65 00 62 00 - 75 00 67 00 04 00 01 03  ..D.e.b.u.g.....
                        000001b0   00 00 ff ff 00 00 fd ff - 32 00 e6 00 58 02 0e 01  ..ÿÿ..ýÿ2.æ.X...
                        000001c0   31 00 00 00 02 01 ff ff - 32 80 00 00 00 00 00 00  1.....ÿÿ2.......
                        000001d0   00 00 12 00 08 55 00 73 - 00 65 00 72 00 46 00 6f  .....U.s.e.r.F.o
                        000001e0   00 72 00 6d 00 04 00 01 - 04 00 00 ff ff 00 00 fd  .r.m.......ÿÿ..ý
                        000001f0   ff 32 00 22 01 58 02 4a - 01 32 00 00 00 02 01 ff  ÿ2.".X.J.2.....ÿ
                        00000200   ff db 00 00 00 97 01 00 - 02 00 00 10 00 00 04 00  ÿÛ..............
                        00000210   01 01 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        00000220   00 00 42 00 00 00 02 01 - ff ff 15 80 00 00 96 01  ..B.....ÿÿ......
                        00000230   00 02 00 00 12 00 15 50 - 00 72 00 6f 00 6a 00 65  .......P.r.o.j.e
                        00000240   00 63 00 74 00 20 00 57 - 00 69 00 6e 00 64 00 6f  .c.t. .W.i.n.d.o
                        00000250   00 77 00 20 00 49 00 6e - 00 73 00 65 00 72 00 74  .w. .I.n.s.e.r.t
                        00000260   00 04 00 01 01 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        00000270   00 00 00 00 00 15 00 00 - 00 02 01 ff ff 16 80 00  ...........ÿÿ...
                        00000280   00 96 01 00 02 00 00 12 - 00 06 54 00 6f 00 67 00  ..........T.o.g.
                        00000290   67 00 6c 00 65 00 04 00 - 01 01 00 00 00 00 00 00  g.l.e...........
                        000002a0   00 00 00 00 00 00 00 00 - 00 00 16 00 00 00 02 01  ................
                        000002b0   ff ff 1b 80 00 00 96 01 - 00 02 00 00 12 00 0b 43  ÿÿ.............C
                        000002c0   00 6f 00 64 00 65 00 20 - 00 57 00 69 00 6e 00 64  .o.d.e. .W.i.n.d
                        000002d0   00 6f 00 77 00 04 00 01 - 00 00 00 00 00 00 00 00  .o.w............
                        000002e0   00 00 00 00 00 00 00 00 - 00 1b 00 00 00 02 01 ff  ...............ÿ
                        000002f0   ff 1c 80 00 00 96 01 00 - 02 00 00 12 00 13 43 00  ÿ.............C.
                        00000300   6f 00 64 00 65 00 20 00 - 57 00 69 00 6e 00 64 00  o.d.e. .W.i.n.d.
                        00000310   6f 00 77 00 20 00 28 00 - 42 00 72 00 65 00 61 00  o.w. .(.B.r.e.a.
                        00000320   6b 00 29 00 04 00 01 00 - 00 00 00 00 00 00 00 00  k.).............
                        00000330   00 00 00 00 00 00 00 00 - 1c 00 00 00 02 01 ff ff  ..............ÿÿ
                        00000340   1d 80 00 00 96 01 00 02 - 00 00 12 00 0c 57 00 61  .............W.a
                        00000350   00 74 00 63 00 68 00 20 - 00 57 00 69 00 6e 00 64  .t.c.h. .W.i.n.d
                        00000360   00 6f 00 77 00 04 00 01 - 00 00 00 00 00 00 00 00  .o.w............
                        00000370   00 00 00 00 00 00 00 00 - 00 1d 00 00 00 02 01 ff  ...............ÿ
                        00000380   ff 1e 80 00 00 96 01 00 - 02 00 00 12 00 10 49 00  ÿ.............I.
                        00000390   6d 00 6d 00 65 00 64 00 - 69 00 61 00 74 00 65 00  m.m.e.d.i.a.t.e.
                        000003a0   20 00 57 00 69 00 6e 00 - 64 00 6f 00 77 00 04 00   .W.i.n.d.o.w...
                        000003b0   01 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        000003c0   00 00 1e 00 00 00 02 01 - ff ff 1f 80 00 00 96 01  ........ÿÿ......
                        000003d0   00 02 00 00 12 00 0d 4c - 00 6f 00 63 00 61 00 6c  .......L.o.c.a.l
                        000003e0   00 73 00 20 00 57 00 69 - 00 6e 00 64 00 6f 00 77  .s. .W.i.n.d.o.w
                        000003f0   00 04 00 01 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        00000400   00 00 00 00 00 1f 00 00 - 00 02 01 ff ff 20 80 00  ...........ÿÿ ..
                        00000410   00 96 01 00 02 00 00 12 - 00 0e 50 00 72 00 6f 00  ..........P.r.o.
                        00000420   6a 00 65 00 63 00 74 00 - 20 00 57 00 69 00 6e 00  j.e.c.t. .W.i.n.
                        00000430   64 00 6f 00 77 00 04 00 - 01 00 00 00 00 00 00 00  d.o.w...........
                        00000440   00 00 00 00 00 00 00 00 - 00 00 20 00 00 00 02 01  .......... .....
                        00000450   ff ff 21 80 00 00 96 01 - 00 02 00 00 12 00 16 50  ÿÿ!............P
                        00000460   00 72 00 6f 00 6a 00 65 - 00 63 00 74 00 20 00 57  .r.o.j.e.c.t. .W
                        00000470   00 69 00 6e 00 64 00 6f - 00 77 00 20 00 28 00 42  .i.n.d.o.w. .(.B
                        00000480   00 72 00 65 00 61 00 6b - 00 29 00 04 00 01 00 00  .r.e.a.k.)......
                        00000490   00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 21  ...............!
                        000004a0   00 00 00 02 01 ff ff 22 - 80 00 00 96 01 00 02 00  .....ÿÿ"........
                        000004b0   00 12 00 0e 4f 00 62 00 - 6a 00 65 00 63 00 74 00  ....O.b.j.e.c.t.
                        000004c0   20 00 42 00 72 00 6f 00 - 77 00 73 00 65 00 72 00   .B.r.o.w.s.e.r.
                        000004d0   04 00 01 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        000004e0   00 00 00 00 22 00 00 00 - 02 01 ff ff 23 80 00 00  ....".....ÿÿ#...
                        000004f0   96 01 00 02 00 00 12 00 - 07 4d 00 53 00 46 00 6f  .........M.S.F.o
                        00000500   00 72 00 6d 00 73 00 04 - 00 01 00 00 00 00 00 00  .r.m.s..........
                        00000510   00 00 00 00 00 00 00 00 - 00 00 00 23 00 00 00 02  ...........#....
                        00000520   01 ff ff 24 80 00 00 96 - 01 00 02 00 00 12 00 0f  .ÿÿ$............
                        00000530   4d 00 53 00 46 00 6f 00 - 72 00 6d 00 73 00 20 00  M.S.F.o.r.m.s. .
                        00000540   43 00 6f 00 6e 00 74 00 - 72 00 6f 00 6c 00 04 00  C.o.n.t.r.o.l...
                        00000550   01 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        00000560   00 00 24 00 00 00 02 01 - ff ff 25 80 00 00 96 01  ..$.....ÿÿ%.....
                        00000570   00 02 00 00 12 00 15 4d - 00 53 00 46 00 6f 00 72  .......M.S.F.o.r
                        00000580   00 6d 00 73 00 20 00 43 - 00 6f 00 6e 00 74 00 72  .m.s. .C.o.n.t.r
                        00000590   00 6f 00 6c 00 20 00 47 - 00 72 00 6f 00 75 00 70  .o.l. .G.r.o.u.p
                        000005a0   00 04 00 01 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        000005b0   00 00 00 00 00 25 00 00 - 00 02 01 ff ff 26 80 00  .....%.....ÿÿ&..
                        000005c0   00 96 01 00 02 00 00 12 - 00 0f 4d 00 53 00 46 00  ..........M.S.F.
                        000005d0   6f 00 72 00 6d 00 73 00 - 20 00 50 00 61 00 6c 00  o.r.m.s. .P.a.l.
                        000005e0   65 00 74 00 74 00 65 00 - 04 00 01 00 00 00 00 00  e.t.t.e.........
                        000005f0   00 00 00 00 00 00 00 00 - 00 00 00 00 26 00 00 00  ............&...
                        00000600   02 01 ff ff 27 80 00 00 - 96 01 00 02 00 00 12 00  ..ÿÿ'...........
                        00000610   0f 4d 00 53 00 46 00 6f - 00 72 00 6d 00 73 00 20  .M.S.F.o.r.m.s.
                        00000620   00 54 00 6f 00 6f 00 6c - 00 62 00 6f 00 78 00 04  .T.o.o.l.b.o.x..
                        00000630   00 01 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        00000640   00 00 00 27 00 00 00 02 - 01 ff ff 28 80 00 00 96  ...'.....ÿÿ(....
                        00000650   01 00 02 00 00 12 00 0b - 4d 00 53 00 46 00 6f 00  ........M.S.F.o.
                        00000660   72 00 6d 00 73 00 20 00 - 4d 00 50 00 43 00 04 00  r.m.s. .M.P.C...
                        00000670   01 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        00000680   00 00 28 00 00 00 02 01 - ff ff 29 80 00 00 96 01  ..(.....ÿÿ).....
                        00000690   00 02 00 00 12 00 10 4d - 00 53 00 46 00 6f 00 72  .......M.S.F.o.r
                        000006a0   00 6d 00 73 00 20 00 44 - 00 72 00 61 00 67 00 44  .m.s. .D.r.a.g.D
                        000006b0   00 72 00 6f 00 70 00 04 - 00 01 00 00 00 00 00 00  .r.o.p..........
                        000006c0   00 00 00 00 00 00 00 00 - 00 00 00 29 00 00 00 02  ...........)....
                        000006d0   01 ff ff 2a 80 00 00 96 - 01 00 02 00 00 12 00 07  .ÿÿ*............
                        000006e0   54 00 6f 00 6f 00 6c 00 - 62 00 6f 00 78 00 04 00  T.o.o.l.b.o.x...
                        000006f0   01 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        00000700   00 00 2a 00 00 00 02 01 - ff ff 2b 80 00 00 96 01  ..*.....ÿÿ+.....
                        00000710   00 02 00 00 12 00 0d 54 - 00 6f 00 6f 00 6c 00 62  .......T.o.o.l.b
                        00000720   00 6f 00 78 00 20 00 47 - 00 72 00 6f 00 75 00 70  .o.x. .G.r.o.u.p
                        00000730   00 04 00 01 00 00 00 00 - 00 00 00 00 00 00 00 00  ................
                        00000740   00 00 00 00 00 2b 00 00 - 00 02 01 ff ff 2c 80 00  .....+.....ÿÿ,..
                        00000750   00 96 01 00 02 00 00 12 - 00 10 50 00 72 00 6f 00  ..........P.r.o.
                        00000760   70 00 65 00 72 00 74 00 - 79 00 20 00 42 00 72 00  p.e.r.t.y. .B.r.
                        00000770   6f 00 77 00 73 00 65 00 - 72 00 04 00 01 00 00 00  o.w.s.e.r.......
                        00000780   00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 2c 00  ..............,.
                        00000790   00 00 02 01 ff ff 2d 80 - 00 00 96 01 00 02 00 00  ....ÿÿ-.........
                        000007a0   12 00 10 50 00 72 00 6f - 00 70 00 65 00 72 00 74  ...P.r.o.p.e.r.t
                        000007b0   00 79 00 20 00 42 00 72 - 00 6f 00 77 00 73 00 65  .y. .B.r.o.w.s.e
                        000007c0   00 72 00 04 00 01 00 00 - 00 00 00 00 00 00 00 00  .r..............
                        000007d0   00 00 00 00 00 00 00 2d - 00 00 00 02 01 ff ff 2e  .......-.....ÿÿ.
                        000007e0   80 00 00 96 01 00 02 00 - 00 12 00 0d 44 00 6f 00  ............D.o.
                        000007f0   63 00 6b 00 65 00 64 00 - 20 00 57 00 69 00 6e 00  c.k.e.d. .W.i.n.
                        00000800   64 00 6f 00 77 00 04 00 - 01 00 00 00 00 00 00 00  d.o.w...........
                        00000810   00 00 00 00 00 00 00 00 - 00 00 2e 00 00 00 02 01  ................
                        00000820   0b 00 01 80 00 00 96 09 - 00 02 01 00 16 00 04 46  .......          .......F
                        00000830   00 69 00 6c 00 65 00 04 - 00 01 01 00 00 00 00 00  .i.l.e..........
                        00000840   00 00 00 00 00 00 00 0f - 01 ac 00 01 00 00 00 03  .........¬......
                        00000850   01 01 01 ea 02 20 00 08 - 00 03 0e 00 00 00 00 80  ...ê. ..........
                        00000860   03 01 01 01 17 00 20 00 - 08 00 03 0f 00 00 00 00  ...... .........
                        00000870   80 03 01 03 01 03 00 20 - 00 00 00 03 11 00 00 00  ....... ........
                        00000880   00 80 03 01 01 01 ed 02 - 21 00 08 00 03 12 00 00  ......í.!.......
                        00000890   00 00 80 03 01 02 01 0c - 02 21 00 08 00 03 14 00  .........!......
                        000008a0   00 00 00 80 03 01 00 01 - 0d 02 21 00 08 00 03 15  ..........!.....
                        000008b0   00 00 00 00 80 03 01 02 - 01 ea 02 20 00 08 00 03  .........ê. ....
                        000008c0   17 00 00 00 00 80 03 01 - 00 01 ea 02 20 00 00 00  ..........ê. ...
                        000008d0   03 18 00 00 00 00 80 03 - 01 02 01 04 00 20 00 08  ............. ..
                        000008e0   00 03 1a 00 00 00 00 80 - 03 01 02 01 ea 02 20 00  ............ê. .
                        000008f0   00 00 03 1c 00 00 00 00 - 80 03 01 02 01 f0 02 20  .............ð.
                        00000900   00 00 00 03 1e 00 00 00 - 00 80 02 01 06 00 08 80  ................
                        00000910   00 00 96 09 00 02 01 00 - 16 00 05 54 00 6f 00 6f  ...          .......T.o.o
                        00000920   00 6c 00 73 00 04 00 01 - 01 00 00 00 00 00 00 00  .l.s............
                        00000930   00 00 00 00 00 00 00 00 - 00 08 00 00 00 03 01 00  ................
                        00000940   01 ae 03 20 00 00 00 03 - 8e 00 00 00 00 80 03 01  .®. ............
                        00000950   00 01 82 02 22 00 00 00 - 03 8f 00 00 00 00 80 03  ...."...........
                        00000960   01 02 01 a2 03 22 00 00 - 00 03 91 00 00 00 00 80  ...¢."..........
                        00000970   03 01 02 01 0a 02 20 00 - 00 00 03 93 00 00 00 00  ...... .........
                        00000980   80 03 01 00 01 12 0a 21 - 00 00 00 03 94 00 00 00  .......!........
                        00000990   00 80 03 01 00 01 ea 02 - 20 00 00 00 03 95 00 00  ......ê. .......
                        000009a0   00 00 80                                           ...
                        Key Name:          HKEY_CURRENT_USER\Software\Microsoft\VBA\7.1\Common\Toolbars
                        Key Name:          HKEY_CURRENT_USER\Software\Microsoft\VBA\7.1\Common\Toolbars\Settings
                        Value 0
                          Name:            Microsoft Visual Basic
                          Type:            REG_BINARY
                          Data:
                        00000000   01 01 00 00 00 00 00 00 - 00 00 01 00 00 00        ..............
                        Frederick Moor
                        Well........
                        Per the solidworks system requirements page (http://www.solidworks.com/sw/support/SystemRequirements.html), it looks like sw2013 (both the EDU and regular versions) will not run on any 64-bit version of win8.  The page is not clear if it will run on x64 Win7.
                        This is probably root cause of my problem (SW2013 EDU on Win8.1 x64).  Not going to spend any more time trying to get sw2013 EDU to run on Win8.1 x.  I'm off to Fry's tonight to get another SSD to build a Win7 machine.
