I am trying to create the part attached using only Sheet Metal, and it seems to be something impossible in Solidworks.So basically is a sheet with 2 bends, and I need to make a bend over a radius in a plane perpendicular over the two bend lines. I've seen the same part made with no problems in Mechanical Desktop! Is somebody that knows how to make intersect bends in Solidworks? I need the part in Sheet Metal in order to obtain the unfolded view.
I'm using Solidworks 2013
Maybe I wasn't clear enough, so I will add some picture. I just can't believe I am the only one who has this problem...
