1 Reply Latest reply on Aug 23, 2013 2:55 PM by Keith Rice
    Show/hide BOM table
    Jela Rose Tano-An
      I made three(3) bom tables and I want to show only one(1) table.
      I recorded a macro but it only records the selecting of bom table.
      Is there a way to show/hide the bom table?
      Also, move the column and rename it using macro?
      Thanks in advance.
        • Re: Show/hide BOM table
          Keith Rice
          Hi Jela,
          This code traverses all BOM tables on the current sheet. For each table, it switches the first two columns, and then hides the table. Hopefully you can use it to achieve your goals.
          If you are not familiar with macros, I would recommend you watch the free videos at my web site (see link below). You will need to have an understanding of programming, the SolidWorks API Help, and the SolidWorks Object Model if you want to become proficient with the API.
          Dim swView As SldWorks.View
          Dim swTableAnn As SldWorks.TableAnnotation
          Dim swAnn As SldWorks.Annotation
          Dim vTableAnns As Variant
          Dim i As Integer
              Set swModel = swApp.ActiveDoc
              Set swDraw = swModel
              Set swView = swDraw.GetFirstView
              vTableAnns = swView.GetTableAnnotations
              If IsEmpty(vTableAnns) = False Then
                  For i = 0 To UBound(vTableAnns)
                      Set swTableAnn = vTableAnns(i)
                      If swTableAnn.Type = swTableAnnotation_BillOfMaterials Then
                          swTableAnn.MoveColumn 0, swTableItemInsertPosition_After, 1
                          Set swAnn = swTableAnn.GetAnnotation
                          swAnn.Select3 False, Nothing
                          swApp.RunCommand swCommands_Hide_Table, Empty
                  Next i
          Keith
          SolidWorks API Video Tutorials
