hi
I want to use transient thermal simulation .i set the total time for simulation 600 seconds but i donot khow how i determine the time increment?
hi
you need to understand how fast the system will and needs to react to the change. you might want to add some details about your inputs and the system and materials you are using. from there someone may have a suggestion. it doesn't hurt to start with a large value and then make it smaller to see if things change significantly.
You may get a quicker answer if you move your question to the Simulation sub-forum.
